Two OSPF NSSA ABR injecting default route
robert.kreinz
I have following design question:
If i have two NSSA ABR's and both are injecting a default route to the NSSA area, which route will win? Is the election of the default route inside the NSSA are based on costs too?
Robert
mheusinger
Level 10
Level 10
every route - including default - will be installed based on
1) internal before external
2) cost
So depending on NSSA type 1 or 2 a router will pick the closest "exit" ABR or perform load sharing in case of equal cost.
Hope this helps! Please rate all posts.
Regards, Martin
Hi Martin,
Thanks for you reply. I had a discussion with one of my colleagues who mentioned that a router inside NSSA perform allways load sharing, even if the costs of the default routes are different and i wasn't so sure anymore who is right :-)
Best regards,
Robert
vinodbharwani
I beliave , which ever has shorted ( Optimal path) to reach NSSA ASBR will win the game
