Two Routers Connectivity in LAN
majed.balsharaf
I am having two routers of 1841 series.In router 1 I am connected with my Cloud Network and in router 2 I am connected for internet.
I need both the wan connectivities to be advertise in my network for my LAN which is configured with DHCP in my ROUTER 1
Now should I connect this both routers in one switch but I'm having 2960 switch :-(
any suggestions,what should I configure Policy base routing or static route.
Router 1
int f0/0
ip add 10.x.x.x 255.255.255.0
description "Connected to LAN"
int f0/1
ip add 172.x.x.14 255.255.255.252
description "Connected to Cloud"
ip dhcp pool LAN
network 10.x.x.0 255.255.255.0
default-router 10.x.x.254
Router 2
int f0/0
ip add 62.x.x.81 255.255.255.252
Please suggest
Thanks.
2 Accepted Solutions
Jeff Van Houten
Level 5
Level 5
Put a LAN address on the remaining interface on router 2, then put a default route on router 1 pointing to router 2s LAN address.
cashqoo
just a suggestion. assuming that the majority of the traffic are internet bound.
hope it helps.
Jeff Van Houten
Level 5
Level 5
I  will implement and reply you back
cashqoo
hope it helps.
