UBR License Conflict
gregpurenetworx
I can't load a permanent license as an evaluation license is already in place. Clearing of the evaluation license fails. Any ideas on how to remove the eval lic?
uBR10K#license clear DS_License subslot 7/0
Feature: DS_License
    1   License Type: Permanent
        License State: Active, In Use
        License Addition: Exclusive
        License Count: 5
        Comment:
        Store Index: 1
        Store Name: Primary License Storage
Are you sure you want to clear? (yes/[no]): yes
% Error: Could not delete in-use license
uBR10K#license clear US_License subslot 7/0
Feature: US_License
        License Count: 20
        Comment:
        Store Index: 0
uBR10K#show license detail subslot 7/0
Index: 1        Feature: DS_License                        Version: 1.0
        License Count: 5/5/0  (Active/In-use/Violation)
        License Priority: Medium
        Store Index: 1
Index: 2        Feature: DS_License                        Version: 1.0
        License Type: Evaluation
        License State: Inactive
            Evaluation total period: 8  weeks 4  days
            Evaluation period left: 8  weeks 4  days
        License Count: 20/0/0  (Active/In-use/Violation)
        License Priority: None
        Store Index: 1
       Store Name: Evaluation License Storage
Index: 3        Feature: US_License                        Version: 1.0
        License Count: 20/20/0  (Active/In-use/Violation)
        Store Index: 0
Index: 4        Feature: US_License                        Version: 1.0
        Store Index: 0
Mike Williams
Level 5
Level 5
Looks like it won't remove the license since you have features configured that are using that license. You will need to remove the configuration that's using the license, remove the eval license, install the perm license, and add the configuration back in.
Mike
Sent from Cisco Technical Support Android App
We have tried to remove the Evaluation license but recieved an error. Is it possible to remove the license while this unit is in a production enviornment? Is there anyway to leave the config in place?
Error output:
uBR10K(config)#license feature evaluation disable DS_License subslot 7/0
Index: 1        License Type: Evaluation
        Lock Type: Not Locked
        License Count: 20
        License Priority: Low
% Error:  License priority modification failed: Selected license line's precedence is in incorrect state
