UBR7200 ip address command missing
Daniel Graham
I have a ubr7200 with MC28U and NPE-G1 running:
Cisco IOS Software, 7200 Software (UBR7200-JK9SU2-M), Version 12.2(33)SCD7, RELEASE SOFTWARE (fc2)
ubr7200-jk9su2-mz.122-33.SCD7.bin
I cannot assign an IP to the cable x/x interface. IP address is not an available command.
No issues with addressing / routing on non cable interfaces.
router(config)#int cable X/X
router(config-if)#ip ?
Interface IP configuration subcommands:
  dhcp                Configure DHCP parameters for this interface
  header-compression  IPHC options
  rsvp                RSVP Interface Commands
  rtp                 RTP parameters
  subscriber          IP session configuration options
  vrf                 VPN Routing/Forwarding parameters on the interface
Is this an IOS limitation on this version or am I missing something? Any comments/direction is appreciated,
0 Replies 0
