uc-520 locale settings
ppillolla
Hello All
By default uc-520 is shipped with US language settings..if I need to setup a different language wich steps should I follow ?
5 Replies 5
paolo bevilacqua
These steps:
http://cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmelocal.html
ppillolla
Thank you for your answer !!!
I know this solution..i have to use the cli and with some instructions I can resolve this issue... but I'd like to know id is there a way to do it using the Cisco Configuration Assistant gui....
No, only CLI.
Consider, for all advanced CME tasks, only the CLI works, the graphic tools either don't do it, do it poorly, and in any case they prevent you how to properly configure a router at a professional level.
Thanks again !!!
I suppose the CLI was the only way...even if during a small course teacher told us we could use either CLI and GUI (and this spunded strange for me)....now I'm sure with your replies I can't do it with GUI.
You are welcome.
Please do rate useful posts using the scrollbox below!
