ISDN Dial On Demand Issue
cannone78
Hi all,
I have an issue with isdn ddr.
I have a backup isdn enable by dialer watch; furthemore I have configured a dialer list to enable isdn to make a kind of isdn test with icmp to verify periodic connectivity.
Here yo are my config:
interface BRI0/1/0
no ip address
encapsulation ppp
dialer pool-member 2
snmp trap isdn-calls
isdn switch-type basic-net3
isdn point-to-point-setup
no cdp enable
interface Dialer2
ip address negotiated
encapsulation ppp
dialer pool 2
dialer idle-timeout 20
dialer string XXX
dialer max-call 2
dialer watch-group 1
dialer-group 1
keepalive 5
no cdp enable
ppp authentication pap callin
ppp pap XXX
ppp multilink
ppp multilink links minimum 2
ip route 10.10.10.10 255.255.255.255 Dialer2
access-list 101 permit ip host 192.168.27.82 host 10.10.10.10
dialer watch-list 1 ip 213.39.245.49 255.255.255.255
dialer watch-list 1 delay route-check initial 120
dialer watch-list 1 delay connect 5
dialer watch-list 1 delay disconnect 10
dialer-list 1 protocol ip list 101
Periodically (once a day) I make a ping to test isdn connectivity (ping source 192.168.27.82 dest 10.10.10.10).
After a reload all works fine but
The problem is that...after a while (few days after the reload) the DDR seems not working no more...
With a debug dialer, the same ping doesn't work..
I've just make IOS upgrade/downgrade..but nothing.
Any ideas?
Just an info: in this period ISDN line is out-of-order so all the attempts are in the failure state (about 51..).
Can it correlate to my problem? As after a certain number of failure trials, the ddr is blocking?
Many thanks in advance for your support
Gianluca
7 Replies 7
Richard Burts
Gianluca
It would be helpful if you would post the output of show isdn status and the output of debug dialer. If we had this information it might show us the problem or at least give some help in what direction to look for the problem.
Rick
Rick
Hi Rick,
thanks for your support.
Here my output before make my test ping to try to activate DDR:
router#sh isdn status
Global ISDN Switchtype = basic-net3
ISDN BRI0/1/0 interface
dsl 2, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 79, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 2 CCBs = 0
The Free Channel Mask: 0x80000003
Total Allocated ISDN CCBs = 0
router#sh dialer
BRI0/1/0 - dialer type = ISDN
Dial String Successes Failures Last DNIS Last status
0 incoming call(s) have been screened.
0 incoming call(s) rejected for callback.
BRI0/1/0:1 - dialer type = ISDN
Idle timer (120 secs), Fast idle timer (20 secs)
Wait for carrier (30 secs), Re-enable (15 secs)
Dialer state is idle
BRI0/1/0:2 - dialer type = ISDN
Di1 - dialer type = DIALER PROFILE
Idle timer (20 secs), Fast idle timer (20 secs)
Dialer state is data link layer up
Number of active calls = 0
Di2 - dialer type = DIALER PROFILE
Dialer state is call pending
019161 0 69 02:18:31 failed Default
As yuo can see there are a lot of failure becuase there is a problem on the isdn concentrator...but this no matter at the moment..
The problem is that if I make a 'debug dialer' and ping with source 192.168.27.82 destination 10.10.10.10...the DDR doesn't work:
router#sh deb
Dial on demand:
Dial on demand events debugging is on
(Of course I'm in terminal monitor...)
ASG-SITE-TEST-2#p
Protocol [ip]:
Target IP address: 10.10.10.10
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 192.168.27.82
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 195.230.254.99, timeout is 2 seconds:
Packet sent with a source address of 192.168.27.82
Success rate is 0 percent (0/5)
ASG-SITE-TEST-2#sh dialer
....output omitted.....
019161 0 69 02:25:10 failed Default
THE PING DOESN'T ACTIVATE THE DDR...(last call is 2h ago...)..even if I've configured the dialer list.
I've no output with my debug dialer...
I don't understand why...
If I make a reload..all works fine..
I've tried IOS 12.3(14T7) ; 12.4(13) ; 12.4(18)..same behavior..
Any idea?
Many Thanks
Gianluca
Gianluca
Thank you for posting the additional details. It is interesting that when you attempt to initiate the call that there is no output in debug dialer. And that is consistent with your observation that not much is happening.
I think that there is a clue to the problem in this line of output from the show dialer for dialer 2:
if the router thinks that there is a call pending then that might explain why it does not initiate another call. I have not experienced a symptom quite like this and I wonder if a shut/no shut or a clear interface (perhaps on both the BRI as well as the dialer) might clear this up.
Rick
Rick
Ok Rick, very interesting....
'Call pending', It could be linked to the fact that I've a lot of failure DNIS??
I've done shut/no shut of bri and dialer interface...and a strange message appear after no shut(I'm always with debug dialer on):
router(config-if)#int dialer2
router(config-if)#shut
router(config-if)#
router(config-if)#
router(config-if)#no shutdown
Jan 28 17:45:54.083: Di2 DDR is shutdown, could not clear interface.
Any idea?
After I've done a clear to of both bri and dialer...
Now with show dialer the state is changed:
But the ping doesn't work yet...
Many many thanks for all your support..very important!
Gianluca
Gianluca
I wonder if this is related to having dialer watch configured on this dialer. As a temporary measure could you remove the dialer watch configuration and see if the behavior changes?
Rick
Rick
Rick I've removed dialer-watch and the ping doesn't work yet.
Shut/no shut again:
router(config-if)#shutdown
Jan 28 18:02:39.226: Di2 DDR: dialer shutdown complete
Jan 28 18:02:41.226: %LINK-5-CHANGED: Interface Dialer2, changed state to administratively down
router(config-if)#int bri0/1/0
Jan 28 18:02:55.758: %LINK-3-UPDOWN: Interface BRI0/1/0:1, changed state to down
Jan 28 18:02:55.758: %LINK-3-UPDOWN: Interface BRI0/1/0:2, changed state to down
Jan 28 18:02:55.810: %LINK-3-UPDOWN: Interface BRI0/1/0, changed state to up
router(config-if)#
Jan 28 18:03:06.170: %LINK-3-UPDOWN: Interface Dialer2, changed state to up
Show dialer:
019161 0 69 03:22:55 failed Default
The ping doesn't work yet...siggh...
Gianluca
Hi Rick,
the problem seems related to call-pending state of dialer as you suggest: every time the dialer goes in this state..tha DDR is blocking.
I think that call-pendinding happens since all the ISDN calls fail since there is a problem in the isdn cloud.
The question is: is it normal that I'm obliged to reload the router to restart DDR? With sht/no shut dialer move to 'idle state'..but DDR remain bolcked.
Many thanks for your support.
Gianluca
