uck9 license
Faisal.Saoud
Level 3
Level 3
Hey,
we have this router and want to know if the license installed is classic or smart, and perpetual or subscribed.
#sh license all
Smart Licensing Status
Smart Licensing is ENABLED
License Conversion:
Automatic Conversion Enabled: False
Status: Not started
Export Authorization Key:
Features Authorized:
<none>
Utility:
Status: DISABLED
Smart Licensing Using Policy:
Status: ENABLED
Data Privacy:
Sending Hostname: yes
Callhome hostname privacy: DISABLED
Smart Licensing hostname privacy: DISABLED
Version privacy: DISABLED
Transport:
Type: Smart
URL: https://smartreceiver.cisco.com/licservice/license
Proxy:
Not Configured
Miscellaneous:
Custom Id: <empty>
Policy:
Policy in use: Merged from multiple sources.
Reporting ACK required: yes (CISCO default)
Unenforced/Non-Export Perpetual Attributes:
First report requirement (days): 365 (CISCO default)
Reporting frequency (days): 0 (CISCO default)
Report on change (days): 90 (CISCO default)
Unenforced/Non-Export Subscription Attributes:
First report requirement (days): 90 (CISCO default)
Reporting frequency (days): 90 (CISCO default)
Enforced (Perpetual/Subscription) License Attributes:
First report requirement (days): 0 (CISCO default)
Report on change (days): 0 (CISCO default)
Export (Perpetual/Subscription) License Attributes:
Usage Reporting:
Last ACK received: Jun 20 19:05:36 2023 KSA
Next ACK deadline: <none>
Reporting push interval: 0 (no reporting)
Next ACK push check: Jun 21 09:34:22 2023 KSA
Next report push: <none>
Last report push: Jun 20 19:00:34 2023 KSA
Last report file write: <none>
Trust Code Installed: Oct 26 10:43:31 2022 KSA
License Usage
uck9 (ISR_4331_UnifiedCommunication):
Description: uck9
Count: 1
Version: 1.0
Status: IN USE
Export status: NOT RESTRICTED
Feature Name: uck9
Feature Description: uck9
Enforcement type: NOT ENFORCED
License type: Perpetual
Product Information
UDI: PID:ISR4331/K9,SN:FDO2544125Q
Agent Version
Smart Agent for Licensing: 5.0.9_rel/68
License Authorizations
Overall status:
Active: PID:ISR4331/K9,SN:FDO2544125Q
Status: NOT INSTALLED
Purchased Licenses:
No Purchase Information Available
#sh ow license sum
#sh ow license sum
#sh ow license sum?
% Unrecognized command
#sh ow license ?
#show licens
#show license sum
#show license summary
License Usage:
License Entitlement Tag Count Status
uck9 (ISR_4331_UnifiedCommun...) 1 IN USE
 You have both. Smat and Classic.
 The Classic is perpetual and the smart licensing is not possible to say. If you have a smart account you need to check there. If you dont, then you might not be usign smat licensing
