Unable to access Cisco 4221 web login page
mayanksahni
We have a cisco 4221 router. When I try accessing its GUI page on https://192.168.10.1 its not letting me access that.
What all I have tried and not working is as follows:
  1. Tried older version of firefox which supports TLS 1
  2. Tried fiddling with the firefox setting security.tls.version
  3. Tried using internet explorer
  4. Tried changing internet options settings for internet explorer
Please help me with that.
PS: I am not a network expert. I am amateur at it. But I can manage configuration through GUI.
30 Replies 30
balaji.bandi
check below link and let me know if tht help you :
https://community.cisco.com/t5/routing/how-to-configure-cisco-4221-web-ui-for-wan-configuration/td-p/4814336
if still issue post below output ;
show version
show logging
show run
show ip ssh
BB
SHOW VERSION
Router>show version
Cisco IOS XE Software, Version 16.08.01
Cisco IOS Software [Fuji], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9_IAS-M), V ersion 16.8.1, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Tue 27-Mar-18 13:43 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2018 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
Router uptime is 20 minutes
Uptime for this control processor is 22 minutes
System returned to ROM by PowerOn
System image file is "bootflash:isr4200-universalk9_ias.16.08.01.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
appxk9
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None None None
securityk9 securityk9 Permanent securityk9
ipbase ipbasek9 Permanent ipbasek9
cisco ISR4221/K9 (1RU) processor with 1788426K/6147K bytes of memory.
Processor board ID FGL2421LVK4
1 Virtual Ethernet interface
6 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7081983K bytes of flash memory at bootflash:.
0K bytes of WebUI ODM Files at webui:.
SHOW IP SSH
Router>show ip ssh
SSH Enabled - version 1.99
Authentication methods:publickey,keyboard-interactive,password
Authentication Publickey Algorithms:x509v3-ssh-rsa,ssh-rsa
Hostkey Algorithms:x509v3-ssh-rsa,ssh-rsa
Encryption Algorithms:aes128-ctr,aes192-ctr,aes256-ctr
MAC Algorithms:hmac-sha2-256,hmac-sha2-512,hmac-sha1,hmac-sha1-96
KEX Algorithms:diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1
Authentication timeout: 120 secs; Authentication retries: 3
Minimum expected Diffie Hellman key size : 2048 bits
IOS Keys in SECSH format(ssh-rsa, base64 encoded): TP-self-signed-1236578148
%SSH: Failed to encode IOS ASN.1 to SECSH format
Router>
Also at ip http secure-server command I am getting the following error:
Router(config)#ip http secure-server
CRYPTO_PKI: setting trustpoint policy for TP-self-signed-1236578148 to specify TP-self-signed-1236578148 keypair usageFailed to generate persistent self-signed certificate.
Secure server will use temporary self-signed certificate.
mayanksahni
@balaji.bandi @Flavio Miranda @azolfi78
Please help me further. I truly appreciate your response.
enable the debug on the router and access the Page from PC and post the debug logs here.
I never had so much difficulty to access GUI for testing :
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/https/configuration/xe-16/https-xe-16-book/HTTP_1-1_Web_Server_and_Client.html
I also suggest to - zero the keys and configures ip ssh version 2
crypto key generate rsa usage-keys modulus 2048
Another thing, you are not getting any prompt at all, or you getting prompt and username and password input later you getting error ?
BB
How to enable debug on router and how will I be able to access the logs?
I performed the steps mentioned in the link but still the same problem persists.
Crypto command says "Please define a hostname other than Router."
I am not getting any prompt at all.
Is it easier if there is a way I could reset everything on router and GUI shows up normally like the other small routers?
If this is not production router, then write erase and reload and start from bootstrap.
below standard base config i use it works as expected :
config t
hostname MyRouter
boot-start-marker
boot-end-marker
enable secret 5 $1$jtK0$yyHFcVM7xyelts1csVwrV/
username cisco privilege 15 secret 5 $1$0qFD$ZEMDi.7z1QTtF4EuPdlSY.
aaa new-model
aaa authorization config-commands
aaa session-id common
clock timezone GMT 0 0
clock summer-time BST recurring last Sun Mar 1:00 last Sun Oct 2:00
no ip domain-lookup
ip domain-name bb.com
ip cef
no ipv6 cef
interface GigabitEthernet0/0
ip address x.x.x.x 255.255.255.0
no shutdow
ip http server
ip ssh version 2
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous level 0 limit 20
stopbits 1
line aux 0
line vty 0
privilege level 15
password cisco
transport input ssh
line vty 1
privilege level 15
password cisco
length 0
transport input ssh
line vty 2 4
privilege level 15
password cisco
transport input ssh
end
######### Generate SSH keys :
BB
Yes, that's not production router and I need its GUI so that I can configure it to use on my existing internet. I am getting various errors with the commands you mentioned. Please see the screenshots attached.
Make sure you read the config and understand, Do not blindly paste, that is suggested configuration - the errors giving because of some features not supported (may be different) - Most of them your ignorance.
x.x.x.x (any where you see the IP like this)
May be you can read the errors and correct (or you looking some one to do for you ?) this is community to help each other to solve the issue, not doing some one else work.
Note : As i mentioned i used base template does not mean you copy and paste there- i would expect as engineer to read the suggested config.
And Last - there is not must you need to have GUI for the router work to get yourself or user to get into internet, you can also do the same configuration on cli - if you understand the commands, if you coming from GUI world then different question/.
BB
Add this config an test
enable
conf t
aaa new-model
ip http authentication local
ip http authentication enable
ip http authentication aaa
username admin privilege 15 secret cisco@123
end
wr
Try
username: admin
password: cisco@123
Thanks for the response. I tried as you mentioned and still facing the same issue. Please find the screenshot attached for the commands that I ran.
With HTTP only?
With HTTPS only its redirecting to HTTPS.
Try to run this commands
crypto pki trustpoint TP-self-signed-12345678148
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-12345678148
revocation-check none
rsakeypair TP-self-signed-12345678148
Now ip http secure-server didn't give the error it was giving before. But issue is still the same.
