unable to access configure terminal in C1121X router
ruch
Hi All,
We recently bought C1121(X) routers. however. we are unable to configure the router as the configure terminal command shows as not supported on the router.
Cisco IOS XE Software, Version 16.12.03
Cisco IOS Software [Gibraltar], ISR Software (ARMV8EL_LINUX_IOSD-UCMK9-M), Version 16.12.3, RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
ROM: IOS-XE ROMMON
Any support would be much appreciated
Mark Elsen
  - Post a screenshot of the command tried including the output ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
M02@rt37
Hello @ruch
It seems like your Cisco C1121(X) router is running in SD-WAN mode (IOSD-UCMK9-M), which explains why the confugre-terminal command is not supported.
Best regards
Giuseppe Larosa
Hello @ruch ,
the devices may have an SD WAN image installed on them
post show version
if so with this kind of version you will need to perfom a procedure to install a regular IOS XE image ( autonomous mode)
be also aware of following bug in your SW version
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvm86435
Hope to help
Giuseppe
even with SDWAN you can access to config t and config it
check the register number
MHM
