unable to access external owa through guest network on wifi
mipl45023
Greetings,
I have setup guest network on our access point, traffic for which goes to second interface on asa and from there to outside. Internet works perfectly and all other websites that are out open without any issues, except the external owa url which is mapped to an internal private ip. so people who are using acrtivesync on the guest network, emails dont work either.
any suggestions. I am not that familiar with the asa. However did find a suggestion when i googled, which did mention about adding a static NAT for inside,guest .
static (inside,inside2) tcp 83.xx.xxx.xxx https 192.xx.xx.xx https netmask 255.255.255.255
there is another static nat already for inside,outside( with the public and the internal ip address of the mail server with https and smtp allowed.
Not sure if it is only the NAT but the routing as well that needs to be done. Also how would i enable ICMP on the guest network interface on the asa. it says it is currently blocked by incoming rule configure on the outside interface.
Guidnace is highly appreciated. I have put the config below.
interface Ethernet0/2
switchport access vlan 50
interface Vlan2
nameif outside
security-level 0
ip address xx.xxx.xx.xxx 255.255.255.248
interface Vlan30
nameif inside
security-level 100
ip address yyy.yyy.yy.yyy 255.255.255.0
interface Vlan50
nameif inside2
security-level 100
ip address zzz.zzz.zz.zzz 255.255.255.0
interface Vlan60
nameif DMZ
security-level 50
ip address rrr.rrr.rr.rrr 255.255.255.0
boot system disk0:/asa825-k8.bin
object-group network obj_any
object-group network VIA-LL
network-object host
network-object host
network-object host
object-group network adj_any
object-group service DM_INLINE_SERVICE_1
service-object icmp
service-object tcp eq ftp
service-object tcp eq ftp-data
service-object tcp
object-group protocol DM_INLINE_PROTOCOL_1
protocol-object ip
protocol-object icmp
access-list Data1 extended permit ip any any
access-list outside-in extended permit tcp any host(exchangepublicIP) eq https
access-list outside-in extended permit tcp any host (exchangepublicip) eq smtp
access-list outside-in extended permit ip 192.168.100.0 255.255.255.0 192.168.20.0 255.255.255.0
access-list outside-in extended permit object-group DM_INLINE_SERVICE_1 any host (FTP)
access-list inside_nat0_outbound extended permit ip any 192.168.100.0 255.255.255.224
access-list inside_nat0_outbound extended permit ip 192.168.30.0 255.255.255.0 192.168.100.0 255.255.255.224
access-list VIA-LL extended permit ip object-group VIA-LL any
access-list ciscoasa_splitTunnelAcl standard permit 192.168.30.0 255.255.255.0
access-list ciscoasa_splitTunnelAcl remark serverlan
access-list ciscoasa_splitTunnelAcl standard permit 192.168.20.0 255.255.255.0
access-list Data2 extended permit object-group DM_INLINE_PROTOCOL_1 any any
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu inside2 1500
mtu DMZ 1500
ip local pool VPN_Pool 192.168.100.5-192.168.100.30 mask 255.255.255.0
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 10 (exchangepublicIP)
global (outside) 20 (outgoingPUblicipNAT)
global (outside) 30 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 30 access-list VIA-LL
nat (inside) 10 192.168.20.40 255.255.255.255
nat (inside) 20 0.0.0.0 0.0.0.0
nat (inside2) 0 access-list inside_nat0_outbound
nat (inside2) 20 192.168.50.0 255.255.255.0
static (inside,outside) exchangepublicIP 192.168.20.40 netmask 255.255.255.255
static (DMZ,outside) FTP 192.168.200.2 netmask 255.255.255.255
static (inside,DMZ) 192.168.200.0 192.168.30.0 netmask 255.255.255.0
access-group outside-in in interface outside
access-group Data1 in interface inside
access-group Data2 in interface inside2
route outside 0.0.0.0 0.0.0.0 RouterOutInterfaceIP 1
route inside 192.168.20.0 255.255.255.0 192.168.30.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
ldap attribute-map Banner1
Raj
Add another access-list entry permitting smtp traffic to actual real IP of your exchange server which is 192.168.20.40
Access-list outside-in ext permit tcp any host 192.168.20.40 eq smtp
This will resolve the issue. Since we are natting public IP to internal exchange server IP, we have to allow traffic which is actually going to the internal server from outside.
Just wanted to confirm,
arent these two lines in the config doing teh same thing.
access-list outside-in extended permit tcp any host (exchangepublicIP) eq https
since the public IP is already natted to the internal server IP address.
thanks again.
i have tried adding the access list , but didnt work. i tried a packet trace and it shows the following result. says acl caused drop.
I have tried adding the acl to allow 192.168.20.40 443 on the guest interface inside2, but no luck.
packet-tracer in inside2 tcp 192.168.50.22 https 83.43.44.45(exchange public IP address) https
Phase: 1
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
static (inside,inside2) tcp 83.43.44.45 https 192.168.20.40 https netmask 25
255.255.255
  match tcp inside host 192.168.20.40 eq 443 inside2 any
    static translation to 83.43.44.45/443
    translate_hits = 0, untranslate_hits = 46
Additional Information:
NAT divert to egress interface inside
Untranslate 83.43.44.45/443 to 192.168.20.40/443 using netmask 255.255.255.2
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-interface: inside2
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
any suggestion on what is going wrong. when i try a ping to 192.168.20.40 from the inside2(guest interface), it shows about some routing issue.
255.255.255
for communications to be allowed between same security interfaces, you need to enable this (run this command in global configuration mode):
same-security-traffic permit inter-interface
