Connecting 2 Cisco 2960s with SFP
elroykhlo
Hi All,
  Recently, I am going to connect 2 Cisco 2960s with Fibre at different floors. Do it need any configuration for connecting 2 switch with fibre and SFP module?
Many Thanks
Best Regards,
Elroy
6 Replies 6
jwood
Will other be multiple vlans that we be used on these switches?
Sent from Cisco Technical Support Android App
Thanks for your quick reply. For my network diagram, is that I will create a VLAN as an external switch to connect between the external router and the firewall. For the rest of switch will share same VLAN for client connection.
Many Thanks
Best Regards,
Elroy
Hello
Give each switch an svi interface and default-gateway (for management purposes)
Trunk interface between the two switches to carry the vlans.
Res
Paul
Kind Regards
Paul
Is be we not it figured what asked?
Hello Jaff,
I dont understand your question?
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
thanks for your reply. Sorry for my limited knowledge, may I ask more about svi interface? And even my client connection share same default VLAN. It is also needed to trunk the SFP port?
Best Regards,
Elroy
