Unable to access from VPN Fortigate to Cisco ASA 5505
CSCO11857702
Problem : Unable to access user A to user B
User A --- router A (122, fortigate 80c) --- (Site to Site VPN between fortigate & cisco asa) --- router B (93, cisco Asa 5505{in front asa got cisco800[81] before to internet} )  --- User B
After using wizard to configure the site to site VPN, the site-to-site tunnel is up.
Ping is unsuccessful from user A to user B
Ping is successful from user B to user A, data is accessable
After done the packet tracer from user A to user B,
Result :
Flow-lookup
Action : allow
Info: Found no matching flow, creating a new flow
Route-lookup
Action : allow
Info : 192.168.5.203 255.255.255.255 identity
Access-list
Action : drop
Config Implicit Rule
Result - The packet is dropped
Input Interface : inside
Output Interface : NP Identify Ifc
Info: (acl-drop)flow is denied by configured rule
Below is Cisco ASA 5505's show running-config
ASA Version 8.2(1)
hostname Asite
domain-name ssms1.com
enable password 2KFQnbNIdI.2KYOU encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
name 82 B-firewall description Singapore office firewall
name 192.168.1.0 B-inside-subnet description Singapore office internal LAN IP
name 192.168.200.0 A-inside-VLAN12 description A-inside-VLAN12 (fortinet)
name 192.168.2.0 fw-inside-subnet description A office internal LAN IP
name 122 A-forti
interface Vlan1
nameif inside
security-level 100
ip address 192.168.5.203 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 93 255.255.255.240
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/7
ftp mode passive
dns server-group DefaultDNS
object-group network obj_any
network-object 0.0.0.0 0.0.0.0
access-list inside_nat0_outbound extended permit ip any 80 255.255.255.240
access-list inside_nat0_outbound extended permit ip fw-inside-subnet 255.255.255.0 B-inside-subnet 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.5.0 255.255.255.0 A-inside-VLAN12 255.255.255.0
access-list outside_cryptomap extended permit ip fw-inside-subnet 255.255.255.0 B-inside-subnet 255.255.255.0
access-list Outside_nat-inbound extended permit ip A-inside-VLAN12 255.255.255.0 192.168.5.0 255.255.255.0
access-list Outside_nat-inbound extended permit ip host A-forti 192.168.5.0 255.255.255.0
access-list outside_1_cryptomap extended permit ip 192.168.5.0 255.255.255.0 A-inside-VLAN12 255.255.255.0
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-631.bin
no asdm history enable
arp timeout 14400
global (outside) 101 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 101 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 81 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http B-inside-subnet 255.255.255.0 inside
http fw-inside-subnet 255.255.255.0 inside
http 0.0.0.0 255.255.255.255 outside
http 0.0.0.0 0.0.0.0 outside
http 192.168.5.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs
crypto map outside_map 1 set peer A-forti
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map 2 match address outside_cryptomap
crypto map outside_map 2 set peer B-firewall
crypto map outside_map 2 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 20
encryption aes-192
hash md5
group 2
lifetime 86400
crypto isakmp policy 30
encryption aes-256
hash md5
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.5.10-192.168.5.20 inside
dhcpd dns 165 165 interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy DfltGrpPolicy attributes
vpn-tunnel-protocol IPSec l2tp-ipsec svc webvpn
username admin password XXX encrypted privilege 15
tunnel-group 122 type ipsec-l2l
tunnel-group 122 ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
class-map outside-class
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
  message-length maximum client auto
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect icmp
policy-map outside-policy
description ok
class outside-class
  inspect dns
  inspect esmtp
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect icmp
  inspect icmp error
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect sip
  inspect skinny
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect xdmcp
service-policy global_policy global
service-policy outside-policy interface outside
prompt hostname context
Cryptochecksum: XXX
: end
Kindly need your expertise&help to solve the problem
169.254.250.1  is a link-local IPv4 address that is autoconfigured by hosts when they can't get a DHCP IP.
Alain
6 Replies 6
CSCO11857702
After using wizard to configure the cisco Asa site to site VPN, the site-to-site tunnel is up.
miltoncaillouet
I had the same problem where i couldn't ping the cisco asa from a fortigate 310 and i had to create a static route on the fortigate to the ASA and i had to create a second policy on the fortigate
Hi Milton Caillouet,
Thanks, I tried to configurate the fortigate :
1. static route
    destination ip/mask : user B network/255.255.255.0
    default gateway : point to cisco ASA wan IP
2. create a firewall policy
Source Interface : external
source add: user A address
Destination Interface: internal
destination add : user B address
with or without NAT
still unable to ping, do i done any missing any step?
After checked between forti firewall and asa, found out same problem that the source was changed/NAT by the ISP during data pass thou' from forti-asa, do I have any solution on that?
4 Apr 01 2013     18:51:16      402116      A-fortifirewall        B-ASA.
IPSEC: Received an ESP packet (SPI= 0x51142CC1, sequence number= 0x1F)
from A (user= A) to B.
The decapsulated inner packet doesn't match the negotiated policy in the SA.
The packet specifies its destination as 192.168.5.204, its source as 169.254.250.1,
and its protocol as 1. The SA specifies its local proxy as 192.168.5.0/255.255.255.0/0/0 and
its remote_proxy as 192.168.200.0/255.255.255.0/0/0.
Alain
Cadet, you are right that the address is belong to link-local IPv4
Dear Milton,  i already create a firewall policy in forti. Besides, it is a default route point to isp router, I configured a static route on fortigate to asa,below shows the network topology and the static route.
Network
forti (router vpn A ) -- isp router -- ipsec -- isp router -- cisco800 -- ciscoASA (router vpn B)
a static route from forti to cisco800
a static route from cisco 800 to ciscoASA
I tried to ping, not working, If i configure a static route from asa to forti, ipsec tunnel dropped.
or i direct configured a static route to asa wan port, it since not working.
It have only default route to isp router on cisco800.
Any1, do I missed up anything or do i need to configure anything on the cisco800 to allow vpn traffic?
