04-28-2010 04:16 AM - edited 03-04-2019 08:18 AM
Attached are the config of our two remote routers one behind the other.
We two have WAN connection links (Radio and fibre) but the radio do not take over network traffic during the fiber link outage.
The fiber link is directly connected on a routed interface while the radio link is virtually connected through a switchport on the same router.
The fiber is connected to router via a fast ethernet media converter, thus the interface always remain up.
We would have to manually shutdown the fiber link interface to force traffic before the radio link can carry traffic .
Please view the configurations on the attached and assist me with your findings.
04-28-2010 05:12 AM
Problem traced to static route on Near end remote router.
Therefore the router ignores ospf at the Near end remote but adheres to it at far remote.
Since the Fiber link interface is connected through a media converter, the interfac will remain always up, and static route keeps depending on it to forward traffic, until it is manually shutdown.
Static route removed and fallover test scheduled for tomorrow.
Any idea on how to take the fiber link interface down in this scenario.
04-28-2010 07:57 AM
Hello Don,
Reliable static routing with object tracking is what you need
see
http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xe/feature/guide/dbackupx.html
so you can use an IP SLA or rtr object (IOS release dependent) to check if IP next-hop is really alive
Hope to help
Giuseppe
