Unable to add ip flow monitor in management interface
djagdale97
I am getting below error when tried to configure ip flow monitor in management interface.
Router(config-if)#ip flow monitor FLOW-MONITOR-IPV4 output
% Flow Monitor: Failed to add monitor to interface: Management Interface Unsupported
Please help me identify the issue.
Dhiraj Jagdale
pman
Is the interface in vrf-Mgmt?
if i'm not mistaken Netflow Export is not supported on the Gig0 interface for ASR1000,
if this is the case then you can export using standard interface.
Hi pman,
Router model is cisco ASR1001-HX
Dhiraj Jagdale
pman
Hi pman,
Received same below reply from TAC. Thanks.
This is purely hardware limitation and is the architecture design of ASR1k device. Management  interface is directly connected to RP. It has no connection with FP at all so Gig 0 cannot be used for netflow or any other configuration. Its purely used for management purpose only. To provide Management access.
Dhiraj Jagdale
