07-04-2021
05:00 PM
- last edited on
07-08-2022
09:40 AM
by
Translator
Hello Expert,
I upgrade my ISR4331/K9 router with the
ios isr4300-universalk9.17.03.03.SPA.bin
I change the boot priority so it can boot from the newest ios .
Unfortunately when I reload the router it kept looping searching for a boot device but unable to locate one.
After a few looping session I press control c and enter
rommon#>
prompt and type the word boot to start from the old ios essential rolling back so the router can use the current ios
It Should during the boot process using old ios this message was displayed
%IOSXEBOOT-4-BOOT_SRC: (rp/0): WARNING: Attempting to use bootflash for package
s storage!
Jul 4 17:45:52.105: %FLASH_CHECK-3-DISK_QUOTA: R0/0: flash_check: Flash disk qu
ota exceeded [free space is 1217524 kB] - Please clean up files on bootflash.
GUY_BCP_CLS1#dir /all
Directory of bootflash:/
40161 drwx 4096 Jul 4 2021 18:01:07 +00:00 .installer
152609 drwx 4096 Jul 4 2021 18:00:43 +00:00 sysboot
11 -rw- 583505498 Jul 24 2019 06:31:40 +00:00 isr4300-universalk9.16.09.02.SPA.bin
120481 drwx 4096 Jul 24 2019 06:40:49 +00:00 core
48193 drwx 4096 Jul 4 2021 18:02:51 +00:00 .prst_sync
56225 drwx 4096 Jul 24 2019 06:38:56 +00:00 .rollback_timer
64257 drwx 4096 Jul 24 2019 06:38:57 +00:00 gs_script
72289 drwx 36864 Jul 5 2021 00:11:48 +00:00 tracelogs
80321 drwx 4096 Oct 9 2019 12:14:48 +00:00 .dbpersist
144577 drwx 4096 Jul 24 2019 06:39:14 +00:00 virtual-instance
12 -rw- 30 Jul 4 2021 18:02:52 +00:00 throughput_monitor_params
88353 drwx 4096 Jul 24 2019 06:40:25 +00:00 onep
13 -rw- 716 Oct 9 2019 12:12:47 +00:00 vlan.dat
14 drwx 4096 Oct 27 2019 15:07:26 +00:00 lost+found
15 -rw- 701717486 Jul 4 2021 17:06:21 +00:00 isr4300-universalk9.17.03.03.SPA.bin
3258179584 bytes total (1244393472 bytes free)
I humbly request if someone can assists me to set the system boot to the new
ios. (isr4300-universalk9.17.03.03.SPA.bin)
Thanks and regards
Solved! Go to Solution.
07-05-2021 07:13 PM - edited 07-05-2021 07:16 PM
@jomo frank wrote:boot system flash:isr4300-universalk9.17.03.03.SPA.bin boot system bootflash:isr4300-universalk9.17.03.03.SPA.bin
These two boot variable statements are incorrect and the reason why the router boots into ROMMON.
ROMMON upgrade is required (mandatory). Have a look at this: Cisco ISR & ASR 1k Routers: IOS-XE/Firmware Upgrade (Install Mode)
@jomo frank wrote:
Another quick question if I need to remove the old ios image can you post the command(s) to do so?.
To remove the incorrect boot variable strings, do the following:
conf t
no boot system flash:isr4300-universalk9.17.03.03.SPA.bin
no boot system bootflash:isr4300-universalk9.17.03.03.SPA.bin
boot system flash bootflash:isr4300-universalk9.17.03.03.SPA.bin
end
wr
07-06-2021
07:36 AM
- last edited on
07-08-2022
09:46 AM
by
Translator
Once the device booting as expected with 17.3
you can use
delete
command
#delete ?
/force Force delete
/recursive Recursive delete
crashinfo-1: File to be deleted
crashinfo-2: File to be deleted
crashinfo-3: File to be deleted
crashinfo: File to be deleted
flash-1: File to be deleted
flash-2: File to be deleted
flash-3: File to be deleted
flash: File to be deleted
nvram: File to be deleted
stby-crashinfo: File to be deleted
stby-flash: File to be deleted
stby-nvram: File to be deleted
stby-rcsf: File to be deleted
07-04-2021 05:06 PM
%FLASH_CHECK-3-DISK_QUOTA: R0/0: flash_check: Flash disk qu ota exceeded
you need to clean up the old IOS and boot with the new one, because of resources it can only take 1 image.
Look at the system requirement section: 17.3.3 release notes :
also, Look at this Bug CSCvh77984
07-05-2021 03:41 AM
Hello Balaji,
I do not know how to remove the old ios could provide some guidance.
07-04-2021 05:56 PM - edited 07-04-2021 06:40 PM
The firmware went form 16.9.X to 17.3.3 so I have two questions:
NOTE: The router is booting the firmware in Bundle Mode.
07-05-2021
03:35 AM
- last edited on
07-08-2022
09:42 AM
by
Translator
Hello Leo,
Did anyone upgrade the ROMMON? no
GUY_BCP_CLS1#sh run | inc boot
boot-start-marker
boot-end-marker
diagnostic bootup level minimal
GUY_BCP_CLS1#sh bootvar
BOOT variable = flash:isr4300-universalk9.17.03.03.SPA.bin,12;bootflash:isr4300-universalk9.17.03.03.SPA.bin,12;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Standby not ready to show bootvar
07-05-2021
05:02 AM
- last edited on
07-08-2022
09:43 AM
by
Translator
You change this to install mode as suggested @Leo Laohoo method.
or change as below :
config t
config-reg 0x2102
copy run start
check show boot
reload and test.
07-05-2021
07:56 AM
- last edited on
07-08-2022
09:44 AM
by
Translator
Hello Balaji,
A quick question what is the reason for removing the two entries below before I make adjustment
07-05-2021 08:30 AM - edited 07-05-2021 08:30 AM
You removing the boot variable and correcting the right image to boot, bundle mode.
07-05-2021 12:55 PM
Hello Balaji,
Thanks for the explanation I will execute the commands you provide tomorrow today is a national holiday.
conf t
end
wr
07-06-2021 08:47 AM
Hello Leo
Thank you
07-06-2021
07:36 AM
- last edited on
07-08-2022
09:46 AM
by
Translator
you can use
delete
command
#delete ?
/force Force delete
07-06-2021 08:46 AM
Hello balaji,
Thank you.
