Unable to configure SR-TE (Segment Routing Traffic Engineering) in CSR 1000v
khalilmeb
Dear all,
I'm trying to configure SR-TE (Segment Routing Traffic Engineering) in CSR 1000v IOS XE 16 using the official tutorial in here Segment Routing Traffic Engineering (SR-TE)
I have the same topology in AWS where 6 CSR 1000v routers are deployed there. When I started the configuration the command
segment-routing
then I got
% Incomplete command.
After I checked the possible commands, I got this:
csr1000v(config)#segment-routing ?
mpls Segment Routing MPLS Mode
Where in the tutorial is showing something else, how can I have the same configuration as it is shown in the tutorial?
ahmed Rbeda
Did you find the solution to this problem?
