Best way to check NAT flow
Richard Tapp
So we have just upgraded an 1111-8P from 16.9.5 to 16.12.8.
We have a static NAT inbound that allows access to a CCTV system. This has worked fine for years.
Now the app wont work. All NAT and ZBF releate config looks the same in a Notepad++ compare.
I am seeing my test traffic hit the outside interface, but not then any more after that.
So I guess this could be ZBF or NAT, I am leaning more towards ZBF at the moment, but struggling how to capture this.
In ZBF we have hostile-DMZ (where the system is) and LAN-DMZ, this one works fine.
Another router we went from 16.12.4 to 16.12.8 which has static inbound NAT is still working ok.
I did try to revert to 16.9.5, but it just cam back up on 16.12.8
It can NAT and /or zone security.
Show ip nat translate <<- share this
MHM
Richard Tapp
This is the one for this NAT
Pro Inside global Inside local Outside local Outside global
--- 212.154.x.x 10.82.70.10 --- ---
But I never see a flow from my public IP when testing
This static NAT it permanent add to NAT entry.
From this it seem that NAT not work at all.
Can I see Router config
MHM
Richard Tapp
Looks like we might be hitting this bug.
https://bst.cisco.com/quickview/bug/CSCwa49729
The dynamic NAT assigns ports for it to use and blocks them out.
sh ip nat portblock dynamic global
tcp:
  7110 -8133   rfcnt 1 6086 -7109   rfcnt 1 5062 -6085   rfcnt 1 545  -617    rfcnt 1
udp:
  5062 -6085   rfcnt 1 512  -584    rfcnt 1
Our flow uses tcp/8000. Later today I will try removing the dynamic and and reapplying the static NAT first to see what happens
