Unable to connect 887VA Router to ISP via ADSL
josejperez1964
I have been trying to connect a  new Cisco 887VA Router to the Internet using ADSL via PPPoE and have  been unsuccessful. The DSL line is active and functioning correctly  since the current "old" router is connected and working without any  problems (the "old" DLink router is connected to an Alcatel DSL Modem).  AT&T provides the ADSL service to the office. When the Cisco Router  is connected it tries to negotiate a connection via PPPoE on the WAN  interface but utlimately fails. The IP for the WAN interface is dynamic.  Any solutions or suggestions would be greatly appreciated.
Below is the current configuration of the router.
! Last configuration change at 00:43:54 UTC Sun Jun 26 2011
version 15.1
no service pad
service password-encryption
hostname xxx-r1
boot-start-marker
boot-end-marker
enable secret 5 xxxx.
no aaa new-model
memory-size iomem 10
ip source-route
ip dhcp excluded-address 192.168.0.1 192.168.0.25
ip dhcp pool xxx-net
   network 192.168.0.0 255.255.255.0
   default-router 192.168.0.1
   dns-server 68.94.156.1 68.94.157.1
   lease 0 22
ip cef
ip domain name xxxx.local
no ipv6 cef
license udi pid CISCO887VA-SEC-K9 sn FTX15040JNR
controller VDSL 0
interface Ethernet0
no ip address
pppoe-client dial-pool-number 1
no fair-queue
interface ATM0
description ADSL to SBC/ATT
no ip address
no atm ilmi-keepalive
hold-queue 224 in
pvc 0/35
bundle enable
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address 192.168.0.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1412
interface Dialer1
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxx@sbcglobal.net
ppp chap password 7 xxxx
ppp pap sent-username xxxx@sbcglobal.net password 7 xxxx
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list NAT-ACL interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list standard VTY-ACL
permit 192.168.0.0 0.0.0.255
ip access-list extended NAT-ACL
permit ip 192.168.1.0 0.0.0.255 any
logging esm config
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
access-class VTY-ACL in
password 7 xxxx
login
transport input all
end
9 Replies 9
mavespig
Level 3
Level 3
Hi Jose,
I'd add "pppoe enable group global" under the ethernet interface, then enable "deb ppp nego" and collect the logs, to check if the negotiation is starting (and why it fails).
Hope this helps
Marco
Hi Marco,
Thanks for responding. I'll check and see what the logs say after adding the "pppoe enable group global" to the config.
Hi Marco,
I added "pppoe enable group global" to the config and then used the following debug command, deb pppoe events. In looking at the log, it showed that PADI's were being sent out through the WAN interface but no PADO's were being received from the ISP. In essence the PADI timer kept expiring (see below). I also checked the status of the interfaces and found that ATM and Dialer interfaces were up and connected but the physical WAN interface (Ethernet 0) was neither up or connected (see below). Any other suggestions you may have would greatly be appreciated.
Log:
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.1(2)T1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 11-Aug-10 18:20 by prod_rel_team
*Jul 18 01:28:35.367: %SNMP-5-COLDSTART: SNMP agent on host xxxx is undergoing a cold start
*Jul 18 01:28:35.375: %SYS-6-BOOTTIME: Time taken to reboot after reload =   76 seconds
*Jul 18 01:28:35.407: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Jul 18 01:28:35.407: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Jul 18 01:28:36.363: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, changed state to down
*Jul 18 01:28:36.363: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to
down
*Jul 18 01:28:36.363: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1, changed state to
down
*Jul 18 01:28:36.363: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet2, changed state to
down
*Jul 18 01:28:36.363: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet3, changed state to
down
*Jul 18 01:29:04.755: %CONTROLLER-5-UPDOWN: Controller VDSL 0, changed state to up
*Jul 18 01:29:06.759: %LINK-3-UPDOWN: Interface Ethernet0, changed state to down
*Jul 18 01:29:13.911: %LINK-3-UPDOWN: Interface ATM0, changed state to up
*Jul 18 01:29:14.911: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to up
*Jul 18 01:29:21.771: PPPoE:ATM0 0/35, Got ATM VC Event
*Jul 18 01:29:21.951: PPPoE:ATM0 0/35, Got ATM VC Event
*Jul 18 01:29:36.511:  padi timer expired
*Jul 18 01:29:36.511:  Sending PADI: Interface = Ethernet0
*Jul 18 01:30:08.767:  padi timer expired
*Jul 18 01:30:08.767:  Sending PADI: Interface = Ethernet0
*Jul 18 01:30:41.047:  padi timer expired
*Jul 18 01:30:41.047:  Sending PADI: Interface = Ethernet0
Interfaces:
Interface                  IP-Address      OK? Method Status                Protocol
ATM0                       unassigned      YES NVRAM  up                    up
Dialer1                    unassigned      YES NVRAM  up                    up
Ethernet0                  unassigned      YES NVRAM  down                  down
FastEthernet0              unassigned      YES unset  up                    down
FastEthernet1              unassigned      YES unset  up                    down
FastEthernet2              unassigned      YES unset  up                    down
FastEthernet3              unassigned      YES unset  up                    down
NVI0                       unassigned      YES unset  administratively down down
Vlan1                      192.168.0.1     YES NVRAM  up                    down
Update IOS.
Hi Paolo,
Thanks for your reply. I was beginning to think an IOS update would be needed. I will download the latest, which is 15.1.3T1 for the 887VA, and do the upgrade.
paolo bevilacqua
You are missing pppoe config under pvc 0/35
Also
interface Vlan1
ip tcp adjust-mss 1452
interface Dialer1
no ip mtu 1452
mtu 1492
no cdp enable
Hi Paolo,
Thanks for the suggestions you provided. I will edit the config as suggested. Hopefully it will work out.
b1services
We have a similar problem with connection, do you have a final config that did work so that we can compare it to our own
slimanikhalil
Did you solve your issue?
If not try this my friend
Controller VDSL 0
                operating mode adsl2+
I've choose ADSL2+ as it's what is provided in Morocco
And don't forget to configure PPPoE on PVC under ATM like that; as this the group you're using in your int Dialer 1:
pvc 8/35
Good luck :-)
