Unable to connect to DMZ and WAN via LAN
HadiBeheshti
Hi, I have a 3750 switch and three 2960 switches and a Kerio firewall.
IP range of 2960 switches: 10.10.31.0/24, 10.10.32.0/24, 10.10.41.0/24
DMZ IP Range: 10.10.10.0/24
LAN IP Range: 10.10.12.0/24
WAN IP Range: 180.140.32.0/24
IP Kerio: 10.10.10.2
Computers on the LAN can see each other. But they do not have access to the server. And do not see DMZ and WAN.
I defined a VLan for DMZ and a separate VLan for LAN.And a VLan for each of the 2960 switches that give devices IP through DHCP.
Thanks for pointing me to how I can modify the code.
I attached the code I used below.
3750 :
enable
configure terminal
hostname SW-Core
ip default-gateway 10.10.10.2
ip domain-name ********
vtp mode server
vtp domain ********
vtp version 2
vtp pruning
enable secret ********
line vty 0 15
password ********
login
exit
line console 0
password ********
login
exit
VLan 10
name DMZ
exit
VLan 12
name CORE
exit
VLan 31
name F3N
exit
VLan 32
name F3S
exit
VLan 41
name F4N
exit
interface vlan 10
ip address 10.10.10.11 255.255.255.0
no shutdown
exit
interface vlan 12
ip address 10.10.12.1 255.255.255.0
no shutdown
exit
interface vlan 31
ip address 10.10.31.1 255.255.255.0
no shutdown
exit
interface vlan 32
ip address 10.10.32.1 255.255.255.0
no shutdown
exit
interface vlan 41
ip address 10.10.41.1 255.255.255.0
no shutdown
interface range gigabitEthernet 1/0/1-6
switchport mode trunk
switchport trunk allowed vlan 1-99
no shutdown
exit
interface range gigabitEthernet 1/0/7-9
switchport mode access
switchport access vlan 10
no shutdown
exit
interface range gigabitEthernet 1/0/10-12
switchport access vlan 12
no shutdown
exit
interface range gigabitEthernet 1/0/13-28
shutdown
exit
ip dhcp pool DMZ
network 10.10.10.0 255.255.255.0
default-router 10.10.10.11
dns-server 10.10.10.2
lease 8
exit
ip dhcp pool CORE
network 10.10.12.0 255.255.255.0
default-router 10.10.12.1
dns-server 10.10.10.10
lease 8
exit
ip dhcp pool F3N
network 10.10.31.0 255.255.255.0
default-router 10.10.31.1
lease 8
exit
ip dhcp pool F3S
network 10.10.32.0 255.255.255.0
default-router 10.10.32.1
lease 8
exit
ip dhcp pool F4N
network 10.10.41.0 255.255.255.0
default-router 10.10.41.1
lease 8
exit
ip routing
ip dhcp excluded-address 10.10.10.1 10.10.10.12
ip dhcp excluded-address 10.10.12.1 10.10.12.10
ip dhcp excluded-address 10.10.31.1 10.10.31.10
ip dhcp excluded-address 10.10.32.1 10.10.32.10
ip dhcp excluded-address 10.10.41.1 10.10.41.10
exit
write
2960 :
enable
configure terminal
hostname SW-F3N
vtp mode client
vtp domain ********
ip default-gateway 10.10.31.1
line vty 0 15
password ********
login
exit
line console 0
password ********
login
exit
interface gigabitEthernet 0/24
no shutdown
exit
interface range gigabitEthernet 0/21-23
shutdown
exit
interface range gigabitEthernet 0/1-20
switchport access vlan 31
no shutdown
exit
interface vlan 1
no ip address
shutdown
exit
interface vlan 31
ip address 10.10.31.2 255.255.255.0
no shutdown
exit
exit
write
Hello
On the 3750 you don’t have a default route to your FW, which you will require when ip routing is enabled, the default-gateway isn’t applicable in this case.
ip route 0.0.0.0 0.0.0.0 vlan 10 10.10.10.2
Lasty does the Fw have routes back towards the lan subnets?
Kind Regards
Paul
Martin Aleksandrov
Hi there,
Kindly address your question to one of the following spaces https://community.cisco.com/t5/switching/bd-p/6016-discussions-lan-switching-routing since here we mostly handle the Cisco Small Business and Cisco Business product lines related queries.
Martin
Hello
Kind Regards
Paul
No how must i do it?!
