unable to connect to internet cisco 2911
paulbrosef
I was at one point able to with it with a DHCP.  I was jumping up and down for joy.  Now I'm back in the trenches, on a battle field hurtling grenades.
I need to set up a static IP address on a computer.  Lets go with 192.168.41.29 netmask 255.255.255.0, gateway 192.168.41.1
I need to connect it into g0/2
I need g0/0 overloaded with 192.168.41.x so that I can ping the internet.  The current configuration is below... please help.
version 15.2
hostname xx
boot-start-marker
boot-end-marker
enable secret 5 xx
no aaa new-model
memory-size iomem 25
no ipv6 cef
ip name-server 68.105.28.16
ip name-server 68.105.29.16
ip cef
license udi pid CISCO2911/K9 sn FTX1648AKVJ
license accept end user agreement
license boot module c2900 technology-package datak9
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description WAN TO INTERNET
 ip address x.x.62.166 255.255.255.248
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description LAN TO INTRANET
 ip address 192.168.42.1 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
interface GigabitEthernet0/2
 description WIRELESS TO FIBER
 ip address 192.168.41.1 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
ip default-gateway x.x.62.161
ip forward-protocol nd
no ip http server
no ip http secure-server
no ip nat service sip udp port 5060
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip nat inside source list 23 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 x.x.62.161
access-list 1 permit 192.168.41.0 0.0.0.255
access-list 23 permit 192.168.42.0 0.0.0.255
control-plane
line con 0
 password xx
 login
line aux 0
 password xx
 login
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 password pass123
 login
 transport input all
scheduler allocate 20000 1000
end
You need to enable routing ie.
"ip routing"
Jon
17 Replies 17
Mark Malone
hey don't think you need 2 overload statements there try this instead
access-list 1 permit 192.168.42.0 0.0.0.255
access-list 1 deny any
Here there!  Thanks for replying!
I went ahead and pulled this beast back behind the wireless so it is no longer exposed to the outside.   I have attached the config so you can review it.  Good to know I can concatenate ip's to an individual access list.  I can ping 192.168.42.5 on the computer, I can ping 192.168.41.1 on the computer.  I can ping google.com from the Cisco router usb console but am unable to ping google.com from the computer.  Just running a laptop connected to g0/2 with 192.168.41.29 as ip, mask 255.255.255.0, gateway 192.168.41.1
version 15.2
hostname tri
boot-start-marker
boot-end-marker
enable secret 5 xx
no aaa new-model
no ipv6 cef
ip cef
redundancy
 no ip address
 shutdown
 description TEMP CONN TO WIRELESS
 ip address 192.168.42.5 255.255.255.0
 ip nat outside
 duplex auto
 speed auto
 no ip address
 ip nat inside
 shutdown
 duplex auto
 speed auto
 ip nat inside
 duplex auto
 speed auto
ip default-gateway 192.168.42.1
no ip http server
ip route 0.0.0.0 0.0.0.0 192.168.42.1
access-list 23 deny   any
access-list 23 permit 192.168.41.0 0.0.0.255
control-plane
line con 0
 password xxx
 login
line aux 0
 password xxx
 login
line 2
 no exec
 transport input all
 stopbits 1
line vty 0 4
 password xxx
 login
 transport input all
end
A couple of things
in your config
access-list 23 deny   any < will stop all packets
access-list 23 permit 192.168.41.0 0.0.0.255 <never get a hit because of line above
so get rid of "access-list 23 deny   any"
also has the 192.168.42.1 device got a route back to the 192.168.41.0/24 network.
" ip route 192.168.41.0 25.255.255.0 192.168.42.5"
Richard.
If I put in ip route I get this error message:
%Invalid next hop address (it's this router)
I still can ping the router and g0/0, g0/2, just not 192.168.42.1 (default Gateway, the wireless router that the cisco 2911 is plugged into from g0/0) from the computer.  Still can ping 192.168.42.1 and google.com from the router.
Ye the acl is on the wrong order they always start from top down from least most specific rule to least usually , going by your original config this is what I would have set to get it running , what the below says is anything coming from the 192.168.41 or 42 network nat to the public ip address , also gives default route as edge route pointing everything out to public ip as that's the only way you can go
 ip nat outside
 duplex auto
 speed auto
 ip nat inside
 duplex auto
 speed auto
 ip nat inside
 duplex auto
 speed auto
Doesn't work.  This is why this is getting frustrating.  Very very frustrating.
To be able to work on this without network interruption on the floor, I have to put this thing behind the cisco wireless.
So here's the new config with your exact changes:
 ip nat outside
 no ip route-cache
 duplex auto
 speed auto
 ip nat inside
 no ip route-cache
 duplex auto
 speed auto
 no ip address
 no ip route-cache
 shutdown
 duplex auto
 speed auto
no ip http server
Except "deny all" gives me:Translating "deny"...domain server (68.105.28.16)
I have a Cisco wireless router facing the internet on network 192.168.42, the bottom 100 are not dynamically assigned so I know .5 works as I can ping out of the router when assigning g0/0 to .5 and "ping google.com".  Which works.  If I call traceroute:
Translating "google.com"...domain server (68.105.28.16) [OK]
Tracing the route to google.com (216.58.219.14)
VRF info: (vrf in name/id, vrf out name/id)
  1 192.168.42.1 4 msec 4 msec 0 msec
  3 wsip-184-176-47-136.sd.sd.cox.net (184.176.47.136) 4 msec 0 msec 4 msec
  4 fed1sysc01-gex0905.sd.sd.cox.net (68.6.8.60) 4 msec 0 msec 4 msec
  5 sanjbprj01-ae0.0.rd.sj.cox.net (68.1.5.184) 20 msec 24 msec 24 msec
  6 paltbprj02-ae1-308.rd.pt.cox.net (68.105.31.37) 20 msec 24 msec 24 msec
  7 216.239.49.168 16 msec 16 msec
    216.239.49.170 24 msec
  8 209.85.246.253 [MPLS: Label 24328 Exp 4] 16 msec
    209.85.246.20 [MPLS: Label 625856 Exp 4] 16 msec
    209.85.246.10 [MPLS: Label 634768 Exp 4] 40 msec
  9 64.233.174.206 [MPLS: Label 304242 Exp 4] 40 msec 16 msec 16 msec
 10 209.85.248.124 16 msec 16 msec 16 msec
 11 209.85.240.107 16 msec 16 msec 12 msec
 12 google.com (216.58.219.14) 12 msec 16 msec 16 msec
So I know I'm connecting.  But the computer can ping the router g0/0 and g0/1 just not the 192.168.42.1 which is the cisco wireless.
The computer is 192.168.41.5/24 with a gateway to 192.168.41.1
What am I missing here??
The solutions to this I'm finding, do not work.
Can you -
1) remove this line from your NAT acl -
2) do a "clear ip nat translations *" on the router
3) ping an internet IP and then post "sh ip nat translations" from your router.
Jon
This is the current config:
I then cleared the nat translation from the router, and I started pinging from both the computer and router different internal ip addresses, including 192.168.41.1 and the 42.1 and google, and "show ip nat translation" does not give any output
Can you post your entire router configuration.
Jon
The entire config is below:
Building configuration...
Current configuration : 1978 bytes
! Last configuration change at 16:03:55 UTC Tue Oct 6 2015
! NVRAM config last updated at 16:04:32 UTC Tue Oct 6 2015
version 15.2
hostname xx
boot-start-marker
boot-end-marker
enable secret 5 xx
no aaa new-model
no ipv6 cef
no ip routing
no ip cef
redundancy
 no ip address
 no ip route-cache
 shutdown
 ip nat outside
 no ip route-cache
 duplex auto
 speed auto
 ip nat inside
 no ip route-cache
 duplex auto
 speed auto
 no ip address
 no ip route-cache
 shutdown
 duplex auto
 speed auto
no ip http server
control-plane
line con 0
 password xx
 login
line aux 0
 password xx
 login
line 2
 no exec
 transport input all
 stopbits 1
line vty 0 4
 password xx
 login
 transport input all
end
"ip routing"
Jon
So you would only want to disable routing for DHCP?  It's working by the way.  Holy lord.  Thank you.  THANK YOU.
You probably wouldn't want to disable routing even if you were using DHCP.
For some reason some of the newer IOSs seem to disable it or that is my experience on these forums.
It's quite rare that you would ever want to manually disable it on a router.
Glad to hear it's working.
Jon
I'm glad too!  I think I can switch this thing out tonight now and I can say I had a rough crash course into cisco configuration.  I can say it was a punch in the face but it is also fascinating.  While I was configuring this thing, I was wondering to myself, how do I programmatically make cisco changes?  If you had a large ISP center and you had these beasts on chassis, it seems ridiculous to configure and make widespread changes just by hunkering around like I did, making individual calls and logging in every time.  Is Python the language of choice for network engineers for making widespread changes or automating network configuration?
