unable to connect to internet cisco 2911
paulbrosef
I was at one point able to with it with a DHCP.  I was jumping up and down for joy.  Now I'm back in the trenches, on a battle field hurtling grenades.
I need to set up a static IP address on a computer.  Lets go with 192.168.41.29 netmask 255.255.255.0, gateway 192.168.41.1
I need to connect it into g0/2
I need g0/0 overloaded with 192.168.41.x so that I can ping the internet.  The current configuration is below... please help.
version 15.2
hostname xx
boot-start-marker
boot-end-marker
enable secret 5 xx
no aaa new-model
memory-size iomem 25
no ipv6 cef
ip name-server 68.105.28.16
ip name-server 68.105.29.16
ip cef
license udi pid CISCO2911/K9 sn FTX1648AKVJ
license accept end user agreement
license boot module c2900 technology-package datak9
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description WAN TO INTERNET
 ip address x.x.62.166 255.255.255.248
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description LAN TO INTRANET
 ip address 192.168.42.1 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
interface GigabitEthernet0/2
 description WIRELESS TO FIBER
 ip address 192.168.41.1 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
ip default-gateway x.x.62.161
ip forward-protocol nd
no ip http server
no ip http secure-server
no ip nat service sip udp port 5060
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip nat inside source list 23 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 x.x.62.161
access-list 1 permit 192.168.41.0 0.0.0.255
access-list 23 permit 192.168.42.0 0.0.0.255
control-plane
line con 0
 password xx
 login
line aux 0
 password xx
 login
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 password pass123
 login
 transport input all
scheduler allocate 20000 1000
end
17 Replies 17
It's certainly one of the scripting languages you can use to automate configuration changes
It really depends on the size of the company etc. as to how much automation they do but there are provisioning tools out there that can help.
Cisco also have management tools for this purpose as well.
If you need to make the same changes on multiple devices then automation can certainly help but there is still a surprising amount done at the CLI.
Once you get familiar with configuring devices it becomes a lot easier.
Jon
Well, I can now configure gigaports in my sleep, got 10 pages open of configuration steps with "live deployment" and "test deployment" config steps lined out in a copy-paste in terminal fashion.  So I think it did get easier.  Next test commences on lunch break for the voip.  After everything is said and done, I'll need to setup telnet and ssh.
Just to add, you should be able to use either use the router as a DHCP server for your clients or use DHCP for the WAN interface IP and still have it work if that is what you want to do.
You would need routing enabled for both.
Jon
