Unable to factory reset ISR 900 series router (c921-4p)
PeterIngels9043
I have tried many times but my old config keeps loading.
There are many different instructions out there on how long to hold the reset pin and when and so on and so forth.
The only info I have found regarding my router is "The reset button is used to restore the router to factory default
settings if pressed within five seconds of router power up".
That does not work.
Snippet from serial port if someone can make somthing out from it:
System Bootstrap, Version 15.8(3r)M0b, RELEASE SOFTWARE (fc1)
Copyright (c) 2018 by cisco Systems, Inc.
Compiled Mon 03-Sep-2018 9:01:14.57
C921-4P platform with 1048576 Kbytes of main memory
System Integrity Status: 0x00000000
Current image running: Upgrade
Last reset cause: Power On
Rom image verified correctly
no valid BOOT image found
Final autoboot attempt from default boot device...
Attempting to boot from [flash:]
Located file c900-universalk9-mz.SPA.158-3.M1.bin
IOS Image Load Test
___________________
RSA Signed RELEASE Image Signature Verification Successful.
Self decompressing the image : ########
Hi all,
That does not work.
this is a characters after pressing  reset button
For those of us wandering here a year or so later -
It takes about 90 seconds from power on to see ROMMON output on the console
Once you see ROMMON begin to boot, press CTRL - C  (instead of the traditional pause/break)
That will drop you into ROMMON.
rommon 1 >
https://www.cisco.com/c/en/us/td/docs/routers/access/900/software/configuration/guide/900SCG/install.html
Worked for me
