Unable to get 1841 DHCP Assigning
Samc2527
I'm pretty new to my studies, but have built a small home lab for practice.  Today I configured two 2960 and one 3560 with with separate vlans and trunks.  Everything seems to be working other than DHCP.
Running config from router:
R1#sh run
Building configuration...
Current configuration : 2090 bytes
! Last configuration change at 22:55:42 UTC Fri Feb 1 2019
version 15.1
service password-encryption
hostname R1
boot-start-marker
boot-end-marker
enable secret 5 $1$X0BP$FgWpZ9gXsyeXW4TZXMN5O0
no aaa new-model
dot11 syslog
ip source-route
ip dhcp excluded-address 192.168.1.1 255.255.255.0
ip dhcp excluded-address 192.168.1.255 255.255.255.0
ip dhcp excluded-address 192.168.2.1 255.255.255.0
ip dhcp excluded-address 192.168.2.255 255.255.255.0
ip dhcp excluded-address 192.168.3.1 255.255.255.0
ip dhcp excluded-address 192.168.3.255 255.255.255.0
ip dhcp pool VLAN101
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 4.2.2.2 8.8.8.8
ip dhcp pool VLAN102
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
ip dhcp pool VLAN103
network 192.168.3.0 255.255.255.0
default-router 192.168.3.1
ip cef
no ipv6 cef
license udi pid CISCO1841 sn FTX0951Z126
redundancy
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.101
encapsulation dot1Q 101
interface FastEthernet0/0.102
encapsulation dot1Q 102
ip address 192.168.2.1 255.255.255.0
interface FastEthernet0/0.103
encapsulation dot1Q 103
ip address 192.168.3.1 255.255.255.0
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
no fair-queue
clock rate 125000
interface Serial0/0/1
no ip address
shutdown
clock rate 125000
interface Serial0/1/0
no ip address
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
logging esm config
control-plane
line con 0
password 7 01100F175804
logging synchronous
line aux 0
line vty 0 4
password 7 13061E010803
login
transport input all
scheduler allocate 20000 1000
end
My end goal was to configure ROAS with three vlans (one for each switch)
Any help is greatly appreciated!
5 Replies 5
balaji.bandi
Do you have  configured helper ?
ip helper-address x.x.x.x
BB
I have not, how and what should this be configured to?
Thank you.
here is the sample config guide to understand also how that works.
https://www.freeccnaworkbook.com/workbooks/ccna/configuring-an-ip-dhcp-helper-address
BB
You don't need IP helper addresses because the pools are on the router.
Can you change these entries -
to
you have defined the exclusions incorrectly ie. you should have the start IP and optionally the end IP but you have used a subnet mask as the second argument and I think the router is excluding all IPs in the pools.
You do not need to exclude the broadcast address for the subnet, the router will not hand that out as a DHCP IP.
Jon
@Jon Marshall  you are right, i missed that..looks like i am missing the numbers today..  Good catch and thank you.
BB
