Unable to log into redundant switch_ssh: connect to host xx.xxx.x.15 port 22: Connection refused
s k
My apologies if I'm unable to put the question right, I am a beginner and would not understand why Im not able to log into the redundant device. These are Cisco WS-6509-E running the WS-SUP720-3B
I am trying to do an IOS upgrade on 2 devices
Device A
Device B (Redundant to Device A)
These are Access level switches and Im using SecureCRT to log into the devices. I am successfully able to log in the Device A and back up the configs. However when trying to log in to Device B - it gives me the below error
ssh: connect to host xx.xxx.z.15 port 22: Connection refused
IP of device A is xx.xxx.z.14.
What can be done in this case? Thanks in Advance !
2 Accepted Solutions
Francesco Molino
With the config it could be easier.
This error can occur if :
- ssh is disabled
- transport input is set to telnet on vty lines
- missing the crypto key
- acl on the switch itself or in between you and this switch (or firewall) filtering ssh access
PS: Please don't forget to rate and mark as correct answer if this answered your question
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Julio E. Moisa
If you cannot log in remotely you should go via console or request connect a PC to reach it remotely.
Now if you are using local credentials like: example:  username Cisco priv 15 password Cisco123
Assuming SSH is already configure, you need to verify the following:
no aaa new-model
crypto key generate rsa  (at least 1024)
ip ssh version 2
line vty 0 15
access-group <ACL> in    <--- if you are using ACL to manage the device, check if your IP address is allowed
transport input ssh
login local
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Francesco Molino
- ssh is disabled
Francesco
Julio E. Moisa
no aaa new-model
ip ssh version 2
line vty 0 15
transport input ssh
login local
Hope it is useful
