DMVPN with VRRP on cisco 4431
nurbol555
Hello all!
I'm trying to configure two routers cisco 4431, first one will be active second one will be backup router, and i'm trying connect this routers with VRRP throught Sub interface. These two routers will be central hub for DMVPN tunnels. My question is will VRRP work with DMVPN? how can i do this? Will DMVPN tunnel works normal with these two routers connected by VRRP or i will have some problem with it? Please give me some advice
Aditya Ganjoo
DMVPN is not supported with HSRP / VRRP.
What you can do is to add each of the routers as NHS and use routing protocol to decide which one should be used.
Aditya
Please rate helpful posts and mark correct answers.
