Unable to make cisco 4300 Series router test Gig bandwidth from ISP
C K
Hi All,
I tried setting cisco 4300 router on a Gig line from ISP and then LAN ports are set to Gig but i am getting 90 Mbs top speed.
If i run test from the ISP router on my laptop with the same Public IPs i am getting 900Mbps + speeds and if i apply the same IPs to g0/0/0 port of 4300 router and then connect my Gig switch 2960 to G 0/0/1 (LAN) and run speed test i am get 90Mbps. I tried connecting my laptop directly to the router and i am still hardly getting100Mbps.
Router is configured with all standard configuration.
IP interface Gig 0/0/0 (Wan) Public IP
IP NAT outside
IP interface Gig 0/0/1 (LAN) Private IP
Ip NAT inside
Ip Dhcp excluded-address [Block of IP]
IP DHCP pool LAN
Network [LAN addres]
default-router [LAN gateway]
DNS server 8.8.8.8
access-list 1 permit [LAN] 0.0.0.255
IP NAT inside source list 1 interface Gig 0/0/0
IP route 0.0.0.0 0.0.0.0 (WAN gateway)
These are the only commands that were configured.
Could you please let me know if i am missing any command to allow Gig traffic .
Kind Regards
C
ASR 4K depends on license you bought it is caped for that capacity.
If you looking WAN Through put you read me last email how can you and limitation and i have suggested models for higher throughput.
Since we are not sure what is the device role how your network, so too mature to suggest here L3 Switch or another device here.
BB
11 Replies 11
balaji.bandi
Can you post show version and sh platform hardware throughput level, what Licenses you have to look.
BB
Hi BB
Please find below version details:
Router#show version
Cisco IOS XE Software, Version 16.03.07
Cisco IOS Software [Denali], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.3.7, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Sat 04-Aug-18 00:44 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2018 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
Router uptime is 3 minutes
Uptime for this control processor is 5 minutes
System returned to ROM by PowerOn at 13:54:47 UTC Fri Feb 8 2019
System image file is "bootflash:isr4300-universalk9.16.03.07.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite                 Suite Current         Type           Suite Next reboot
FoundationSuiteK9     None                  None           None
securityk9
appxk9
AdvUCSuiteK9          None                  None           None
uck9
cme-srst
cube
Technology Package License Information:
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
appxk9           None             None             None
uck9             None             None             None
securityk9       securityk9       Permanent        securityk9
ipbase           ipbasek9         Permanent        ipbasek9
cisco ISR4331/K9 (1RU) processor with 1650780K/6147K bytes of memory.
Processor board ID FLM2041W0GP
3 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3223551K bytes of flash memory at bootflash:.
0K bytes of  at webui:.
Sorry missed out the Platform Throughput level:
It is:
100000 Kb/s
That is 100MB only.
BB
How do i change it to Gig in that case. Sorry i am new to Cisco.
or you can buy a boost license.
Enable temporary throughput license on the router. It will be available for next 60 days. Don’t forget to save your configuration and reload the chassis to take effect.
ISR(config)#platform hardware throughput level 300000
Note : 4331  max support 300MB.
you need 4431 or  4451 for 1GB / 2GB.
BB
Is that Cisco Standard settings?
We got this brand new router?
Yes that is standard, everything you need to buy based on requirement.
BB
Sorry i am confused, as both the ports (G0/0/0 and G0/0/1 if connect to my laptop shows Gig connectivity in Windows Ethernet card properties? But still I am getting 90Mbs on internet. Are you saying this is controlled by a license?
Will the fiber port not help if i get a fiber cable from the ISP router and connect it to my 4300?
BB
