Unable to ping from Boffice to Aoffice-Help
I want to connect Aoffice to Boffice using cisco1800
Senario is like this.
Aoffice 192.168.169.0/24
Boffice 192.168.0.0/24
from Aoffice i have connected through 3com Bridge
Aoffice (Bridge1-192.168.169.254)------>(Bridge2-192.168.169.252)--->CiscoWan port192.168.169.174-Lanport 192.168.0.64)--->Boffice switch.
But I am to ping all the wal and lan ports but not from the Boffice pc to Aoffice PC
LAN   : 192.168.0/24
LAN IP: 192.168.0.64
WAN   : 192.168.169.0/24
WAN IP: 192.168.169.174
My Router config.
no ip domain lookup
interface FastEthernet0/0
ip address 192.168.169.174 255.255.255.0
ip nat outside
speed auto
full-duplex
no mop enabled
interface FastEthernet0/1
ip address 192.168.0.64 255.255.255.0
ip nat inside
speed auto
full-duplex
no mop enabled
router rip
redistribute connected
network 192.168.0.0
network 192.168.169.0
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1
ip route 192.168.0.0 255.255.255.0 192.168.169.252
ip route 192.168.169.0 255.255.255.0 FastEthernet0/1
ip http server
access-list 1 permit 0.0.0.0 255.255.255.0
dialer-list 1 protocol ip permit
control-plane
line con 0
line aux 0
line vty 0 4
password cisco1
login
end
Rick Morris
Level 6
Level 6
In your config you have 3 static routes.  This is what each is saying.
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1 <--Send all traffic not matching specific static out Fa0/1
ip route 192.168.0.0 255.255.255.0 192.168.169.252   <---Traffic destined for 192.168.0.0/24 go out next-hop 192.168.169.252
ip route 192.168.169.0 255.255.255.0 FastEthernet0/1 <---Traffic destined for 192.168.169.0/24 go out interface Fa0/1
Which router is this config?
What are the IP's for A router?
What are the IP's for B router?
It appears that your LAN is connected to Fa0/1 and your WAN is connected to Fa0/0  In your static route you are sending your 192.168.169.0/24 traffic back out the same interface you are connected to.  Based on what you are setting up it should be the 192.168.169.0/24 should go out Fa0/0 which would be your WAN connection.  I am also making an assumption that this network is the B side router.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800ef7b2.shtml
I am using only one router. Office A is using 192.168.169.0/24
                                       Office B is using 192.168.0.0/24
Which router is this config? Cisco 1800
What are the IP's for  Router  LAN I: 192.168.0.64    WAN IP 192.168.169.174
The config you provided is that at Office A or Office B
Again, your static routes need to be verified with what you want.  If you are using 192.168.169.174 as your WAN, the WAN interface is FastEthernet 0/0 so your static routes need to use that interface as their exit point.  You do not have your static routes set up that way.  You are using your LAN interface for all your internet traffic, even your 0.0.0.0 route is using the LAN interface, according to your config you posted.
Sir,This is my complete configuration
My problem is I can ping from 192.168.167.x to 192.168.169.x any PV IP but I am not able to ping 192.168.167.x PC
Site 1
