Unable to ping router from switch
jman1
I am unable to ping my router when I have my config as so:
interface GigabitEthernet0/0/1
description Data Vlan - MX64 Link
ip address 172.30.139.1 255.255.255.0
ip helper-address 172.30.101.21
no ip redirects
ip nat inside
no cdp enable
h323-gateway voip interface
h323-gateway voip bind srcaddr 172.30.139.1
ip virtual-reassembly
When my config is like below, I can ping the router:
interface GigabitEthernet0/0/0.139
encapsulation dot1Q 139
no ip redirects
ip nat inside
no cdp enable
My switch port link is configured as so:
interface GigabitEthernet1/0/52
description Link to ROUTER
switchport mode trunk
Router link:
description Link to Switch INSIDE
no ip address
negotiation auto
I'm trying to save some ports and direct connect to my router as apposed to having multiple connectings com into my switch and over my trunk.
8 Replies 8
Tinashe Ndhlovu
If I understood you requirement correctly
on the switch change this
To this:
switchport mode access
switchport access vlan 139
I have 3 other vlans. Do I need to add access for those as well?  Edit: Still not able to pint my router from my switch when applying the suggested config.
No. just the one vlan and you will be able to ping the router. You do have another port on the switch connecting to your router right? Carrying the other vlans... if not then I would need more detailed info regarding your setup
That is the only connection between the switch and router.
Router:
no ip address
negotiation auto
interface GigabitEthernet0/0/0.10
description Vlan to Fiber Network
encapsulation dot1Q 10
ip address 172.20.10.139 255.255.255.0
no cdp enable
service-policy output WAN-QOS
interface GigabitEthernet0/0/0.99
shutdown
interface GigabitEthernet0/0/0.104
description Imaging and Test LAN
encapsulation dot1Q 104
ip address 172.30.104.2 255.255.255.0
ip helper-address 172.30.102.81
interface GigabitEthernet0/0/0.200
description VOICE
encapsulation dot1Q 200
ip address 10.30.139.1 255.255.255.0
ip nat inside
no cdp enable
no ip redirects
ip nat inside
negotiation auto
no cdp enable
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
Switch:
interface FastEthernet0
no ip address
shutdown
interface GigabitEthernet1/0/1
description link to Charter EPLAN
switchport access vlan 10
switchport trunk native vlan 10
switchport trunk allowed vlan 10
speed 100
duplex full
interface GigabitEthernet1/0/2
description Copper Link to Switch BAY2960Xb
interface GigabitEthernet1/0/3
description Link to MX64
interface GigabitEthernet1/0/4
switchport voice vlan 200
spanning-tree portfast
I want to plug my fiber network into my switch and plug the MX connection directly into my router.
Is the router not routing for the other vlans??
It is routing all the Vlans.
Sorry man it's late night out here explain to me exactly what you are trying to achieve... you wanna save ports where? On the switch or router? Or you don't want every vlan to have access to you router etc
Just trying to save ports on the switch. I had this all connected and working with all my uplinks connected to the switch trunked over to the router via gi0/0/0 with sub interfaces for my vlans. It's not a big deal if I am unable to set it up via gi0/0/1 on the router but I was just curious as to why it would not work. Thanks.
