Route to 2nd Internet Location in another Office? Tell Internal L3 Switch that there is a new Route to Internet?
stownsend
Level 2
Level 2
We are looking to build in some redundancy in our network.
We currently have Inter-Office Links and all of the Offices access the Internet from HQ.
If HQ is destroyed to the ISPs are offline, we wanted to be able to route traffic to the 2nd ISP in another office. Though the Gear that Tells where the Internet is online is the Firewall. If the Firewall Survives but the HQ ISP does not, the HQ Firewall knows that the internet link is down, though the L3 switch routing to that firewall does not know that the ISP is down as the firewall is its default gateway.
How can the Upstream L3 Switch/Router get notified from the HQ firewall that we need to switch to another Internal Firewall to use the 2nd ISP from another office?
Does that make sense?
HQ Firewall - ASA 5525X
L3 Switches - SG500 and SG300
If we need to replace equipment, we understand.
Static routing is a good choice when there are not many alternatives to choose between about how to get to a destination and when you expect the network to be very stable. That may have been a good description of what your network has been like. But now you are adding additional paths that might be chosen and you want to react when the primary ISP becomes not available. These requirements are better satisfied by a dynamic routing protocol.
Many of us tend to think of EIGRP and OSPF as better routing protocols than RIP, especially because they scale to large sizes better and converge more quickly than RIP. But for a network that is small and not complex, like your is, I believe that RIP is a very satisfactory choice of protocol (and especially appropriate since there are devices in your network that support RIP but not EIGRP or OSPF). So go for RIP.
Rick
Rick
Richard Burts
We do not know much about your environment and that makes it difficult to give good advice. If you are using static routing between the firewall and the L3 switch it would be challenging and perhaps some type of SLA on the switch could test for connectivity to the ISP and change the default route if the ISP becomes unreachable. The better solution would be to have a dynamic routing protocol running so that the firewall can advertise the default route when the ISP is available and withdraw that default route if the ISP becomes unavailable. This would presume that the other office participates in the routing protocol and advertises its default route but with a worse metric so that it would only be used if the primary ISP is not working.
Rick
Rick
Currently it is all Static Routing.  Talk about dusting off some brain cells. (-;  Of Course. RIP, EIGRP, etc.
Looks like the ASA supports both RIPv2 and EIGRP. The SG300/SG500 seem to only support RIPv2.
We currently have the SGX00 units routing about 6 VLANs across three Directly Connected sites. The Firewall connects up another 8 Home Offices.
I would Assume that RIP would be enough to do this? I would rather not have to update the Core SGX00 Switches to routers or the Catalyst series.
Thanks!
Rick
Rick
We used EIGRP back in '95 when we had 5 Schools and 4 remote offices all connected with ISDN and T1s.  Its been so long since we have needed any Dynamic routing that I totally spaced its use.
I appreciate the Feedback!
