Unable to Ping through 2901 router
msrbelfast
I'm unable to get my ping through this router, any idea why?
There were a lot of redundant OSPF processes and advertised routes on your routers. I put everything in OSPF process 1 and removed all the redundant stuff. Attached the revised file...
7 Replies 7
johnd2310
Level 8
Level 8
To help we need more info. What is the configuration of the router and how is it connected to the network?
John
**Please rate posts you find helpful**
Hopefully the attached will work - Router 3 is the one that I think is where the problem lies.
Any idea?
Hey, thank you very much! I appreciate that!
Martin L
like ping from PC1 to PC5 , we have L3 issue , no route to R3 on bottom router.  check your ospf routes , make sure all are advertised.
Regards, ML
**Please Rate All Helpful Responses **
why do you have multiple different OSPF processes running on the routers, is that on purpose ?
