Unable to reach host of the network e and network f
I tried ip routing twice but it is not working, i dont know whats wrong in network e and f. i am unable to ping the offsite router but i can ping my own router.
can anyone please help me with the routing of this two networks.
thanks its urgent
plz
there is a simple typo on interface Serial6/0 of the Offsite router:
interface Serial6/0
ip address 192.18.50.250 255.255.255.252
needs to be:6
interface Serial6/0
ip address 192.168.50.250 255.255.255.252
6 Replies 6
Chris McCann
Which router are you pinging from, can you show the routing table. Also what does a traceroute indicate?
this is for router offisite.
there is no .zip attachment...
heres the file pkt file inside the zip
interface Serial6/0
needs to be:6
interface Serial6/0
Thanks the issue is solved,
Can you tell me why the static IP address, subnet mask, default gateway assigned to a host laptop or desktop connected to a wireless access point in a wireless LAN changes to 0 (gets removed completely) after reboot?
Is there any way to stop it like save it. Otherwise I have to reconfigure it every time and there are over 50+ devices in that network.
I'm unable to figure this, I have to submit my project
