Unable to route outside router via GRE/IPsec tunnel
SteveG18
I have a tunnel set up with a 10.22.32.1 address on one side, and 10.22.32.2 on the other.  So, a GRE/IPsec tunnel, sharing some routes, and that part is fine.  From the non-cisco side I can ping across the tunnel to the cicso, and if I traceroute, can see the traffic from the non-cisco device leaving and getting across the tunnel.  Its just not leaving out the cisco router to 8.8.8.8 and making its way back.
You can see the traceroute just stopping at the 10.22.32.1 address:
traceroute to 8.8.8.8 (8.8.8.8), 30 hops max, 46 byte packets
1 10.22.32.1 (10.22.32.1) 22.370 ms 21.942 ms 22.274 ms
2 * * *
3 * * *
4 * * *
I've included the current router config.  If you see something that I'm missing, please let me know??
Current configuration : 5810 bytes
! Last configuration change at 12:57:44 MDT Tue May 28 2024 by steve
! NVRAM config last updated at 10:01:16 MDT Wed May 22 2024 by steve
version 16.6
service timestamps log datetime localtime
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname ttce_dmvpn
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa authorization network default local
aaa session-id common
clock timezone MST -7 0
clock summer-time MDT recurring 1 Sun Mar 2:00 1 Sun Nov 2:00
ip domain name tg.local
subscriber templating
license udi pid ISR4321/K9 sn FDO214428GN
diagnostic bootup level minimal
username ******** privilege 15 password 0 ********
redundancy
mode none
crypto ikev2 proposal IKEV2_PROPOSAL
encryption aes-cbc-256
integrity sha512
group 20
crypto ikev2 policy IKEV2_POLICY
crypto ikev2 keyring IKEV2_KEYRING
peer ANY
address 0.0.0.0 0.0.0.0
pre-shared-key UsMESGQcWqkdKvyNVIqy
crypto ikev2 profile IKEV2_PROFILE
match identity remote any
authentication remote pre-share
authentication local pre-share
keyring local IKEV2_KEYRING
crypto ikev2 dpd 30 15 on-demand
crypto ikev2 limit max-in-negotation-sa 1000
vlan internal allocation policy ascending
crypto ipsec security-association replay disable
crypto ipsec security-association replay window-size 512
crypto ipsec transform-set AES256/SHA512/TRANSPORT esp-aes 256 esp-sha512-hmac
mode tunnel
crypto ipsec profile IPSEC_PROFILE
set transform-set AES256/SHA512/TRANSPORT
set pfs group20
set ikev2-profile IKEV2_PROFILE
interface Loopback0
description INTERNAL - Management Interface
ip address 10.118.0.7 255.255.255.255
no ip redirects
interface Loopback1
description EXTERNAL - DMVPN Hub Interface
ip address 123.195.127.16 255.255.255.255
no ip redirects
interface Loopback2
description Anycast for C_P route tracking
ip address 10.118.0.193 255.255.255.255
no ip redirects
interface Loopback3
description Test Interface
ip address 10.128.0.10 255.128.0.0
interface Tunnel100
description INTERNAL - DMVPN Inside Interface
ip address 10.22.32.2 255.255.240.0
no ip redirects
ip mtu 1300
ip nhrp authentication 1234
ip nhrp map multicast 65.111.237.229
ip nhrp map 10.22.32.2 65.111.237.229
ip nhrp network-id 1
ip nhrp nhs 10.22.32.1
ip nhrp redirect
no ip split-horizon
ip tcp adjust-mss 1260
load-interval 30
keepalive 10 3
tunnel source GigabitEthernet0/0/0
tunnel mode gre multipoint
tunnel key 1234
tunnel protection ipsec profile IPSEC_PROFILE
interface GigabitEthernet0/0/0
ip address dhcp
negotiation auto
interface GigabitEthernet0/0/1
no ip address
negotiation auto
interface GigabitEthernet0/0/1.25
encapsulation dot1Q 25
ip address 10.100.100.11 255.255.255.0
vrrp 2 ip 10.100.100.12
interface GigabitEthernet0/1/0
interface GigabitEthernet0/1/1
switchport access vlan 30
switchport mode access
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
vrf forwarding Mgmt-intf
no ip address
negotiation auto
interface Vlan1
no ip address
interface Vlan30
description C_P Management Interface
ip address 12.0.0.4 255.255.252.0
router bgp 65501
bgp router-id 10.118.0.7
bgp log-neighbor-changes
bgp listen range 10.22.32.0/20 peer-group BBR_C_P
bgp listen limit 2500
neighbor BBR_C_P peer-group
neighbor BBR_C_P remote-as 65005
address-family ipv4
bgp redistribute-internal
network 10.0.0.0
network 10.22.32.0 mask 255.255.240.0
network 10.118.0.193 mask 255.255.255.255
redistribute static
neighbor BBR_C_P activate
neighbor BBR_C_P route-map FROM_DMVPN_PEERS in
neighbor BBR_C_P route-map TO_DMVPN_PEERS out
default-information originate
exit-address-family
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 200.0.0.0 255.255.255.252 10.100.100.10
ip ssh version 2
ip prefix-list DEFAULT_ROUTE seq 10 permit 0.0.0.0/0
ip prefix-list DMVPN_ANYCAST_LOOPBACK seq 10 permit 10.118.0.193/32
ip prefix-list DMVPN_C_P seq 10 permit 10.22.32.0/20 le 32
ip prefix-list STORES seq 10 permit 10.128.0.0/9 le 32
logging trap debugging
logging source-interface GigabitEthernet0/1/0
logging host 10.100.0.5
route-map RIP_TO_BGP permit 10
match ip address prefix-list STORES
route-map FROM_DMVPN_PEERS permit 10
route-map TO_DMVPN_PEERS permit 10
match ip address prefix-list DEFAULT_ROUTE
set as-path prepend 65501 65501
route-map prepend_outbound permit 10
route-map TO_DMPVPN_PEERS permit 20
match ip address prefix-list DMPVPN_ANYCAST_LOOPBACK
control-plane
line con 0
transport input none
stopbits 1
line aux 0
stopbits 1
line vty 0 4
transport input ssh
ntp server time.google.com
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
ttce_dmvpn#
Hello @SteveG18 ,
if this router, ttce_dmvpn, is the DMVPN hub, then the configuration on the Tunnel 100 is not right - on the DMVPN hub you don't need to map anything - this is only done on the spokes.
You should remove the following commands from interface Tunnel 100:
Hope this helps.
Regards, LG
*** Please Rate All Helpful Responses ***
interface Tunnel100
no ip redirects
ip mtu 1300
ip nhrp map 10.22.32.2 65.111.237.229 <<-10.22.32.1 correct this
ip nhrp redirect
no ip split-horizon
load-interval 30
keepalive 10 3
tunnel key 1234
