unable to schedule recurring reloads with CLI
Tiago Marques
Hello ,
I have been unable to schedule recurring reloads on my VOIP routers.
I need Restart Every month the router ... I've set :
RVOIP1(config)#kron policy-list reloadrouter
RVOIP1(config-kron-policy)#cli reload
RVOIP1(config-kron-policy)#exit
RVOIP1(config)#kron occurrence reloadrouter at 04:00 1 recurring
RVOIP1(config-kron-occurrence)#policy-list reloadrouter
RVOIP1(config-kron-occurrence)#exit
RVOIP1(config)#exit
RVOIP1#wr mem
on the first day of each month at 4:00 the router restarts
after running, the router drops cli reload command.
Dec  1 23:30:50.011: Major 1, Minor 0
Dec  1 23:30:50.011: Timer Event reloadrouter
Dec  1 23:30:50.011: Kron delay for next reloadrouter 2592000000
Dec  1 23:30:50.023: Call parse_cmd 'reload'
Dec  1 23:30:50.043: Kron CLI return 0
**CLI 'reload':
System configuration has been modified. Save? [yes/no]: Proceed with reload? [confirm]'
Dec  1 23:30:50.047: Major 4, Minor 7
Dec  1 23:30:50.047: Respond to end of CLI Process
Dec  1 23:30:50.047: Forcing Removing Policy reloadrouter
Dec  1 23:30:50.047: Removing Policy reloadrouter
Dec  1 23:30:50.047:     Removing CLI 'reload'
Dec  1 23:30:50.047: Done Removing Policy reloadrouter
I know that EXEC commands that generate a prompt or can be terminated using keystrokes will result in an error on execution
but not exist one workaround using cli??
0 Replies 0
