Unable to set PPP Multilink on interface BRI0 and dialer, IOS 15.2(3)T
mescheries1
Hi Everyone,
I am configuring ISDN Interface on 2 Cisco 886VA Version 15.2(3)T . I am unable to set ppp multilink on the BRI0 interface and on the dialer interface. It's like the command doen't exist anymore.
How can I fix that so that i can have 128 K bandwidth between ma 2 sites ?.
Thank you
Router1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Router1(config)#int bri0
Router1P(config-if)#ppp multilink
% Invalid input detected at '^' marker.
Router1(config-if)#
Router1(config-if)#ppp ?
  accm              Set initial Async Control Character Map
  accounting        Set PPP network accounting method
  acfc              Options for HDLC Address & Control Field Compression
  authentication    Set PPP link authentication method
  authorization     Set PPP network authorization method
  bcp               Set BCP negotiation options
  bridge            Enable PPP bridge translation
  callback          Set PPP link callback option
  caller            Caller option when no CLID is available
  chap              Set CHAP authentication parameters
  direction         Override default PPP direction
  disconnect-cause  Set disconnect-cause code
  dnis              Authentication via DNIS before LCP
  eap               Set EAP authentication parameters
  encrypt           Enable PPP encryption
  ipcp              Set IPCP negotiation options
  iphc              Set IPCP Header Compression control options
  ipv6cp            Set IPV6CP negotiation options
  lcp               PPP LCP configuration
  link              Set miscellaneous link parameters
  loopback          PPP loopback options
  max-bad-auth      Allow multiple authentication failures
  max-configure     Number of conf-reqs sent before assuming peer is unable to
                    respond
  max-failure       Number of conf-naks sent before assuming configuration is
                    not converging
  max-terminate     Number of term-reqs sent before assuming peer is unable to
                    respond
  ms-chap           Set MS-CHAP authentication parameters
  ms-chap-v2        Set MS-CHAP-V2 authentication parameters
  ncp               Set NCP link parameters
  pap               Set PAP authentication parameters
  pfc               Options for Protocol Field Compression
  quality           Set parameters related to Link Quality Monitoring (LQM)
  timeout           Set PPP timeout parameters
nickbonifacio
Hi Albert,
Did you do encapsulation PPP first?  If it still doesn't work, you might have to use a dialer interface.
Looks like you can set up the BRI and then associate it with a Dialer.
http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/mlppp_over_dial_external_docbase_0900e4b1805ef04c_4container_external_docbase_0900e4b1810bd04a.html
Thanks!
Nick
Nick Bonifacio CCIE #38473
It's doen't work neither on the dialer interface. The command is not it the dialer context
here is my config
Router1#show run
Building configuration...
Current configuration : 2160 bytes
version 15.2
no service pad
service password-encryption
hostname Router1
boot-start-marker
boot-end-marker
enable secret 5 ----------------------------
no aaa new-model
memory-size iomem 10
clock timezone est -5 0
clock summer-time est recurring
--More--
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
no ip domain lookup
ip cef
no ipv6 cef
isdn switch-type basic-ni
license udi pid CISCO886VA-K9 sn FGL1633278M
username Router2 password 7 -----------------------
controller VDSL 0
interface Ethernet0
no ip address
shutdown
interface BRI0
description connection isdn au routeur de laval
no ip address
encapsulation ppp
dialer rotary-group 1
dialer-group 1
isdn termination multidrop
isdn point-to-point-setup
isdn spid1 123456789000 4567890
isdn spid2 123456785200 4567852
isdn fast-rollover-delay 5
no cdp enable
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
description conecte au sous reseau 911laval
ip address 192.168.224.1 255.255.255.0
interface Dialer1
ip address 133.133.134.1 255.255.255.0
encapsulation ppp
no ip split-horizon
dialer in-band
dialer idle-timeout 999999
dialer map ip 133.133.134.2 name 911LavLavP broadcast 91234565864
dialer map ip 133.133.134.2 name 911LavLavP broadcast 91234565816
dialer hold-queue 10
dialer load-threshold 3 either
dialer-group 1
ppp authentication chap
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 192.168.16.0 255.255.248.0 133.133.134.2
dialer-list 1 protocol ip permit
line con 0
password 7 ---------------------------
logging synchronous
login
transport output all
line aux 0
line vty 0 4
password 7 -------------------------------------
logging synchronous
login
transport input all
end
Router1#
I know this is very old but I ran into the same issue and searched this forum.
Solution is to upgrade license to Advanced IP Services, works fine.
Hope this helps others ...
Michael
Please rate all helpful posts
Michael Please rate all helpful posts
