03-30-2011 03:12 AM - edited 03-04-2019 11:55 AM
Dear all
the problem which i am facing rite now is a telnet session after establishing a vpn to our branch office given below is a router config
note: tuunnel is establishes and showing active state
Router#sh crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst src state conn-id slot status
94.x.x.x 94.x.x.x QM_IDLE 2001 0 ACTIVE
IPv6 Crypto ISAKMP SA
router config is below
Building configuration...
Current configuration : 2059 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$uiYN$LFoF7dtH2wm8haGjFIXRO/
no aaa new-model
resource policy
ip cef
username scg privilege 15 secret 5 $1$n1xQ$Rlf9XVA67WZ5lxPKPyUo90
controller DSL 0
line-term cpe
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key cisco address 0.0.0.0 0.0.0.0
crypto ipsec transform-set TSET esp-3des esp-md5-hmac
crypto dynamic-map DMAP 1000
set transform-set TSET
set pfs group2
match address 100
crypto dynamic-map vpn 20
set pfs group5
match address 100
crypto map SMAP 10 ipsec-isakmp dynamic DMAP
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet0
switchport access vlan 10
interface FastEthernet1
switchport access vlan 20
interface FastEthernet2
switchport access vlan 30
interface FastEthernet3
interface Vlan1
no ip address
interface Vlan10
ip address 94.x.x.x 255.255.255.248
ip nat outside
ip virtual-reassembly
crypto map SMAP
interface Vlan20
ip address 192.168.0.1 255.255.255.0
ip nat inside
interface Vlan30
ip address 10.1.1.1 255.255.255.0
ip nat inside
ip route 0.0.0.0 0.0.0.0 94.x.x.x
no ip http server
no ip http secure-server
ip nat inside source list 101 interface Vlan10 overload
access-list 100 permit ip 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 100 permit ip 192.168.0.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 101 deny ip 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 101 deny ip 192.168.0.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
scheduler max-task-time 5000
end
when ever i try to take a remote desktop of 192.168.0.2 from 192.168.1.100 it failed. w8ng for reply
regards
Aftab Ahmed
03-30-2011 07:37 PM
Aftab
I am somewhat confused about the issue that you face. The beginning of your post talks about a problem with telnet. The end of your post says that attempts to Remote Desktop fail. So is this a problem with telnet or is it a problem with RDP?
Rick
03-31-2011 01:18 AM
Rick
my mistake
we are testing our gsm devices for vpn and the ip given are for test pc so its for remote desktop
regards
Aftab
03-31-2011 07:29 AM
What is the result if you add the return traffic to the 'interesting traffic acl'?
access-list 100 permit ip 192.168.1.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 100 permit ip 192.168.2.0 0.0.0.255 192.168.0.0 0.0.0.255
03-31-2011 07:37 PM
Davy
While this is a very logical suggestion, it is not how the ACL for interesting traffic for VPN works. Each side of the VPN connection only needs to permit the "interesting" traffic from their side. The operation of the ACL is smart enough to handle response traffic, without requiring explicit configuration of permits for the response traffic.
Aftab
It is helpful to know that the problem is RDP and not telnet. So thanks for the clarification.
There are a couple of things that I would suggest:
- is it possible that the PC to which you attempt to connect is running a firewall and the firewall is preventing access?
- can you test connectivity from the main site to the remote site PC, ping or traceroute?
- can you verify that the PC will accept RDP sessions? Can you RDP to it from a PC on its local subnet?
Rick
[added] I am interested in your reference to gsm devices. Can you tell us a bit about this and how it relates to the VPN connection?
03-31-2011 11:33 PM
You're right!
Also usefull is to do a ping to the station or its default gateway
04-03-2011 03:44 AM
I have completely remove the previous config and configure newly now the vpn tunnel is working fine i can access remote desktop of my pc in vlan 20 from other side but now pc in vlan 20 is unable to access internet and if i apply access-list to allow the traffice vpn tunnel goes down given below is the curren config
Router#sh running-config
Current configuration : 1523 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
controller DSL 0
line-term cpe
encr 3des
hash md5
group 2
set pfs group2
match address 100
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface Vlan1
no ip address
interface Vlan10
crypto map SMAP
interface Vlan20
ip nat enable
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
end
thanks and regards
Aftab Ahmed
04-03-2011 02:05 PM
Aftab
I am glad that your new config has resolved the problem with VPN and RDP access. I believe that the reason that the PC can not access the Internet is that it is configured with private addressing (192.168.0.x) and there is not any address translation configured. If you configure address translation then the PC should have Internet access.
Be careful that configuring address translation does not impact the existing VPN functionality. And at least now, if you configure address translation and theVPN stops working then you will know exactly where to look to find the problem.
Rick
04-03-2011 10:00 PM
Rick
thanks for your reply as i had configured nat and its access list to allow access to internet for client in vlan 20 but after doing this vpn traffic stop
given below is the previous config
access list 100 is for vpn traffic and access list 101 is for internet
regards
Aftab Ahmed
04-03-2011 10:38 PM
Hi Aftab Ahmed,
ACL looks good. Please check if you have "ip nat enable" on both inside and outside interface.
Kasi
04-03-2011 10:43 PM
Hi kasi
thanks for your reply actually the problem is with vpn traffic when ever i allow internet traffic vpn traffic goes down
regards
Aftab Ahmed
04-03-2011 11:05 PM
Can you try the below config once again.
interface Vlan10
ip nat outside
crypto map SMAP
interface Vlan20
ip nat inside
If the above config works, I believe you need to have IP nat enable on both inside and outside interface for VPN to differenciate the traffic. If possible attach the complete config.
Kasi.
04-03-2011 11:11 PM
Kasi
given below is the previous config in which vpn traffic stopped and internet goes ok
encr 3des
hash md5
group 2
set pfs group2
match address 100
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface Vlan1
no ip address
interface Vlan10
ip nat outside
crypto map SMAP
interface Vlan20
ip nat inside
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
end
04-03-2011 11:23 PM
Dear ,
Do you have a static IP for rthe other end VPN Peer . If so I prefer to configure to mention that static IP
crypto isakmp key Cisco address x.x.x.x (where X.x.x.x is the VPN peer ip address)
set peer X.x.X.x
Other thing, after enabling VPN are you able to see the nat translations on the router ? Which DNS you are using ? Are you able to ping any outside IP address after enabling NAT or it is just a browsing issue
Haris P
04-03-2011 11:30 PM
Haris
I dnt have a static ip on other side thats why configured dmap
2ndly when i configured nat vpn traffic goes down the main problem is of vpn traffic not the access to internet
regards
Aftab Ahmed
