04-04-2011 12:37 AM - edited 03-04-2019 11:58 AM
I understood that there is a limitation on ME 6524 regarding q-in-q vlan mapping on a single interface at 8 mapping maximum, in Cisco documentation was written ISL and not 802.1q...
Does anybody know if there is a fix ?
Or how can I bypass this limitation ?
Example of the Cisco 6500ME with vlan remapping:
QinQ trunk 802.1q with a MetroEthernet provider
interface GigabitEthernet1/31
description Provider MetroEthernet connection
switchport
switchport trunk allowed vlan 120,180,260,309,340,370,864,935,1035
switchport mode trunk
switchport vlan mapping enable
switchport vlan mapping 864 309 <-------------- vlan remapping
switchport vlan mapping 935 120 <-------------- vlan remapping
etc
etc
switchport vlan mapping 370 180 <-------------- vlan remapping up to maximum 8
mtu 9216
no ip address
Tks
Solved! Go to Solution.
04-04-2011 10:57 AM
HI,
It's a hardware limitation so there is nothing you can do about it. Also please be aware that on the following platforms, vlan map is not supported on ports 1-24:
ME6524GS-8S
ME6524GT-8S
Laurent.
04-04-2011 10:57 AM
HI,
ME6524GS-8S
ME6524GT-8S
Laurent.
04-05-2011 11:53 PM
ok
tks
