Unable to upgrade rom-monitor ISR4331
henrique.afonso
#upgrade rom-monitor filename bootflash:isr4400_rommon_1612_2r_SPA.pkg all
Chassis model ISR4331/K9 has a single rom-monitor.
Upgrade rom-monitor
Target copying rom-monitor image file
rsync: link_stat "rommon/mcp/RP/SWORD/latest.bin" (in rommon_upgrade_pub) failed: No such file or directory (2)
rsync error: some files could not be transferred (code 23) at /auto/mcpbuilds21/release/03.16.02.S/BLD-V03_16_02_S_FC2/contrib/rsync/main.c(1392) [receiver=2.6.9]
md5 and hash were verified and they are correct.
#sh rom-monitor r0
System Bootstrap, Version 15.4(3r)S5, RELEASE SOFTWARE
Copyright (c) 1994-2015 by cisco Systems, Inc.
Any ideas?
henrique.afonso
Solved the issue with this rom:
  • isr4200_4300_rommon_1612_2r_SPA.pkg
sh rom-monitor r0
System Bootstrap, Version 16.12(2r), RELEASE SOFTWARE
Copyright (c) 1994-2019 by cisco Systems, Inc.
sh ver | i Software
Cisco IOS XE Software, Version 17.03.04a
Cisco IOS Software [Amsterdam], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 17.3.4a, RELEASE SOFTWARE (fc3)
9 Replies 9
marce1000
 - Check if file is available in remote repository , double check file name , also post
initial
command given for
rommon-install
 M.
Leo Laohoo
Post the complete output to the command
sh platform
henrique.afonso
Chassis type: ISR4331/K9
Slot Type State Insert time (ago)
0 ISR4331/K9 ok 4d21h
0/0 ISR4331-3x1GE ok 4d21h
1 ISR4331/K9 ok 4d21h
R0 ISR4331/K9 ok, active 4d21h
F0 ISR4331/K9 ok, active 4d21h
P0 PWR-4330-AC ok 4d21h
P2 ACS-4330-FANASSY ok 4d21h
Slot CPLD Version Firmware Version
0 15030325 15.4(3r)S5
1 15030325 15.4(3r)S5
R0 15030325 15.4(3r)S5
F0 15030325 15.4(3r)S5
In the initial post i posted the
initial
command for the rom upgrade.
                          >...In the initial post i posted the initial command for the rom upgrade.
 Use
show logging
after attempted
rommon-upgrade
attempt , look for additional info's if any , what software version is the ISR running, if possible upgrade to latest advisory release and try
rommon-upgrade
again afterwards.
 M.
That is why I need to upgrade the rommon.....
Cisco IOS XE Software, Version 03.16.02.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S2, RELEASE SOFTWARE (fc2)
And I have already uploaded the new IOS to the router:
sh run | i boot
boot-start-marker
boot system flash bootflash:isr4300-universalk9.17.03.04a.SPA.bin
boot system flash bootflash:isr4300-universalk9.03.16.05.S.155-3.S5-ext.SPA.bin
boot-end-marker
Ok, I think I know what this is.
I do not think it is possible to go from 15.X.Xr to 16.X.Xr is a single upgrade.  Try an intermediate version, like 16.4(3r), and see if the upgrade works.  IF the upgrade to 16.4(3r) works, then upgrade to the final version.
                     >....That is why I need to upgrade the rommon.....
 - Aligning with Leo's remarks  : first upgrade the ISR to the nearest version which does not need
rommon-upgrade
. Then try
rommon-upgrade
again.
 M.
henrique.afonso
sh rom-monitor r0
sh ver | i Software
gevans
Did anyone get a proper solution to this?
I am getting the same error and the solution just says sh rom-monitor r0 above. I have tried using a different rommon version too and I get the same errror:
RTR#$ilename bootflash:isr4200_4300_rommon_169_1r_SPA.pkg all
Chassis model ISR4431/K9 has a single rom-monitor.
Upgrade rom-monitor
rsync: link_stat "rommon/mcp/RP/OVLD/latest.bin" (in rommon_upgrade_pub) failed: No such file or directory (2)
rsync error: some files could not be transferred (code 23) at /auto/mcpbuilds27/release/03.16.04b.S/BLD-V03_16_04B_S_FC1/contrib/rsync/main.c(1392) [receiver=2.6.9]
RTR#
