09-08-2011 02:58 PM - edited 03-04-2019 01:32 PM
Hello, I would like to upgrade rommon on my Cisco 2801 but this is what I get:
Router#upgrade rom-monitor file flash:C2800NM_RM2.srec.124-13r.T11
This command will result in a 'power-on reset' of the router!
Continue? [yes/no]: yes
ROMMON image upgrade in progress.
Erasing boot flash eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Programming boot flash ppppppppppp
Now Reloading
System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 2006 by cisco Systems, Inc.
The router stops here and I am forced to power off and on again and the upgrade does not succeed.
Thanks in advance for any suggestions.
09-08-2011 04:37 PM
try this one
This is for 2801
C2801_RM2.srec.123-8r.T9 | |
Release Date: 06/OCT/2008 | |
C2801 ROMMON Upgrade; Use with IOS 12.3( | |
Size: 856.43 KB (876981 bytes) Here is the link to it: HTH Reza |
09-10-2011 11:09 PM
Just thought of sharing a useful URL when upgrading ROMMON
09-11-2011 04:51 PM
Now Reloading
Your ROMmon file wasn't "accepted". You are upgrading to T11 but the router is continuously using the T version.
09-11-2011 06:24 PM
Matteo,
The ROMMON image C2800NM_RM2.srec.124-13r.T11 is not suitable for C2801 in particular. It would run in 2811, for example, but specifically for 2801 routers, this ROMMON image is not compatible. That is the reason the upgrade fails: the router cannot boot with this ROMMON so after a next power-on, it reverts back to the primary ROMMON stored in its immutable ROM memory.
The latest ROMMON image for 2801 is the C2801_RM2.srec.124-13r.T5, see
Try this one and let us know if the upgrade finally worked for you.
Best regards,
Peter
01-26-2012 02:52 AM
It is listed in 2801's downloads though. Probably by error.
01-26-2012 04:16 AM
Certainly an error. I had some troubles personally with the ROMMON upgrade until I've found out that the image in fact does not suit the 2801 platform.
Note the "NM" naming - it always refers to higher 2800 routers than 2801. That was my first clue.
Best regards,
Peter
10-19-2012 01:11 PM
It's almost a year later now, and this - C2800NM_RM2.srec.124-13r.T11 is still listed as the latest release for the 2801. Is that still wrong?
10-20-2012 03:40 PM
Hi Edward,
Yes, it is still wrong.
Best regards,
Peter
10-22-2012 02:17 AM
Can you please post the complete output to the command "sh version"?
10-22-2012 05:15 AM
I haven't started the update yet, I needed to be sure I had the right files first.
Cisco IOS Software, 2801 Software (C2801-SPSERVICESK9-M), Version 15.1(2)T1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 11-Aug-10 13:18 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
router uptime is 2 years, 2 weeks, 5 days, 2 hours, 8 minutes
System restarted at 11:37:30 EDT Fri Oct 1 2010
System image file is "flash:c2801-spservicesk9-mz.151-2.T1.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 2801 (revision 7.0) with 239616K/22528K bytes of memory.
Processor board ID FTX133482ZL
2 FastEthernet interfaces
4 Voice FXO interfaces
4 Voice FXS interfaces
1 DSP, 8 Voice resources
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
126000K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO2801 XXXXXXXXXX
07-31-2013 05:34 AM
31-07-2013 file is still there..
Spend 30 minutes solving this .. rommon is still there for the CISCO8201 .. but does not work at the CISCO2801 that i have here..
Great Cisco .. remove the file please
