Understanding CEF
anand.dahiya
Hi all
Just wanted to know how CEF works. What happen to first packet: - it get routed or switched.
Peter Paluch
With CEF, even the first packet is switched. The CEF is built using the routing table as the source of information. Therefore, it is topology-driven and does not require actual packets to flow through the router as the normal route cache does.
This article is a wonderful overview of various switching methods in Cisco IOS, including CEF. Check it out!
http://www.cisco.com/en/US/tech/tk827/tk831/technologies_white_paper09186a00800a62d9.shtml
Best regards,
Peter
CEF is Packet forwarding Mechanism ………..
In simple words …… I can say It will Map your Entire routing table to Next Hop ………
So any User want to Communicate the packed will receive by router & it will see CEF table were to forward …….. The time for each packet will reduce ……… and your Packet forwarding will be fast ………..
