Understanding HSRP Operation on the Catalyst 3650
Translator
Community Manager
Community Manager
Use two Catalyst 3650 for HSRP redundancy.
There are two units, #1 and #2, with a high priority of #1.
In this configuration, if you disconnect all the cables in #1 and only connect #1, #2, all HSRPs in #1 will become active.
Do you know anything about this phenomenon?
M02@rt37
This issue occurs because HSRP does not inherently detect loss of upstream connectivity if the active router (#1) maintains its link to the standby router (#2).
As a result, #1 stays 'active' even when isolated from the network, causing traffic disruption.
So, use HSRP interface tracking to monitor critical uplinks and lower the active router’s priority if a link goes down, forcing a failover to the standby router. Also, enable preemption to allow #1 to reclaim the active role when its links are restored.
Best regards
Thank you very much. It seems that you can switch the route based on the information you gave.
In Catalyst 3560 version 12.2, #1's #2 priority did not change, and #1's State was Init, #2's State was Active, and the path was switched.
Catalyst 3650 In version 16.6, the state of #1 seems to be Active, so has the specification changed or is there a special setting?
→ Sorry, this behavior was a misunderstanding of me, and version 12.2 was doing the same behavior as version 16.6.
