Understanding My Current Router Problem with NIM-ES2-4 Card installed
JNCloud
R1:
FE0/0: 192.161.20.1/24
Local Lan IP
FE0/1: 192.161.21.1/29
Outside Lan IP
Nat PC1 192.161.21.2
Nat PC2 192.161.21.3
Nat PC3 192.161.21.4
IP Route 192.161.20.0 255.255.255.0 192.161.21.0
IP Route 192.161.21.0 255.255.255.0 192.161.20.0
R2:
Local Lan IP
FE0/1: 192.161.22.1/29
Outside Lan IP
Nat PC1 192.161.22.2
Nat PC2 192.161.22.3
Nat PC3 192.161.22.4
IP Route 192.161.20.0 255.255.255.0 192.161.22.0
IP Route 192.161.22.0 255.255.255.0 192.161.20.0
R3:
FE0/0: 192.161.21.6/29
Receive data from R1
FE0/1: 192.161.22.6/29
Receive data from R2
Vlan100:
Local Devices at R3
192.161.24.1/28
NIM-ES2-4:
GE0/1/0:
Switchport access vlan 100
GE0/1/1:
GE0/1/2:
GE0/1/3:
IP Route 192.161.21.0 255.255.255.0 192.161.24.0
IP Route 192.161.22.0 255.255.255.0 192.161.24.0
I am working in packet tracer and trying to understand why my NIM-ES2-4 will not allow me to ping or pass traffic to R1 and R2. The layout above the issue is I can ping devices when logged into R3 using the NAT IP but when attempting the same thing on from a PC connected to the NIM card using example 192.161.24.11. I can’t ping any of the NAT IPs, but I can ping the Interface IP that is in R3. I have been reading lots of things online and think I have gone in a circle withing these forums and decided to finally post. I am under the impression I am missing something simple here. Any advice is appreciated.
Kind Regards,
Mark Elsen
         - FYI : Community group for Packet Tracer project questions
   M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thank you for the reply but poking around in these files that i have already found are not helpful the have provided me concepts and ideas to attempt but without explaining why I am have my problem in the first place? I would like to understand why I having the problem I am having and possible reasons why one solution is better over the other. Feedback is appreciated
I do not claim expertise in PT and have no advice to offer about that aspect. But I do note one thing in the router information that you you post: the static routes on each router make no sense and should be deleted.
Rick
