Understanding the interface types that NBAR runs on (supports)
Translator
Community Manager
Community Manager
Learn about the types of interfaces that enable and work with NBAR.
Specifically, the command to be input is "ip nbar protocol-discovery". The model is the Catalyst 9300 with IOS-XE version 17.12.4.
The setting is included in the Trunk port and the member port of the Layer 2 Port-Channel, but when checking with the show ip nbar protocol-discovery command, no communication is detected and the counter value is not counted up.
Does it work only on the Access port?..
DanielP211
Hello!
I don't belive NBAR will work on L2 interfaces. You have to enable it on L3/SVI's.
BR
****Kindly rate all useful posts*****
Hello
It works ONLY on L3 interfaces  = ip nbar protocol-discovery
Kind Regards
Paul
