Unexpected BPDU Packet from an empty switch
lebanonit
I have a 3750 Stack on my network with several VLANs.  One of these VLANs is 100.
I configured a switch that is also using vlan 100 on every port.  I plug a cable from a port on my stack to the newly configured switch with nothing else plugged into that new switch and I get Unexpected BPDU packet on the stack and the port is shut down.
FastEthernet1/0/2 is down, line protocol is down (err-disabled)
  Hardware is Fast Ethernet, address is 0013.7f0c.1c04 (bia 0013.7f0c.1c04)
  Description: None
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:15, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     9 packets input, 1507 bytes, 0 no buffer
     Received 6 broadcasts (6 multicasts)
     0 watchdog, 6 multicast, 0 pause input
     37 packets output, 4730 bytes, 0 underruns
     0 output errors, 0 collisions, 6 interface resets
On the New Switch it says
FastEthernet0/1 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 0011.5c00.3101 (bia 0011.5c00.3101)
  MTU 1522 bytes, BW 100000 Kbit, DLY 100 usec,
  Last input 00:04:28, output 00:04:27, output hang never
     22 packets input, 2492 bytes, 0 no buffer
     Received 22 broadcasts (0 multicasts)
     0 watchdog, 8 multicast, 0 pause input
     6 packets output, 1004 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
Nothing else is plugged into that switch I just connected.  Any idea why I am getting this?
7 Replies 7
Richard Burts
It sounds like the new switch sent a spanning tree BPDU on its port, which would be expected behavior if it is configured as a normal access port. It sounds like the 3750 did not expect to receive a BPDU. Can you post config of the 3750 (at least the config of the interface and of show run | inc span).
Rick
Rick
interface FastEthernet1/0/2
 description 100
 switchport access vlan 100
 switchport mode access
 spanning-tree portfast
Is this what you are looking for?
That is the configuration of the interface and it looks quite normal. Could you also post the output of these commands
show run | inc span
show spanning-tree
I am wondering if something like BPDUGUARD is enabled.
Rick
Rick
Here is the output with the commands specified:
show run | inc span
spanning-tree mode mst
spanning-tree portfast bpduguard default
no spanning-tree optimize bpdu transmission
spanning-tree backbonefast
spanning-tree mst configuration
spanning-tree mst 1 priority 24576
no spanning-tree vlan 34,100
show spanning-tree
MST0
  Spanning tree enabled protocol mstp
  Root ID    Priority    0
             Address     2880.2346.9460
             Cost        220000
             Port        135 (GigabitEthernet3/1/3)
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32768  (priority 32768 sys-id-ext 0)
             Address     001e.13a1.ee80
Interface           Role Sts Cost      Prio.Nbr Type
Gi2/0/1             Desg FWD 20000     128.55   P2p Edge
Fa2/0/2             Desg FWD 200000    128.58   P2p Edge
Fa2/0/4             Desg FWD 200000    128.60   P2p Edge
Fa2/0/7             Desg FWD 200000    128.63   P2p Edge
Fa2/0/8             Desg FWD 200000    128.64   P2p Edge
Fa2/0/10            Desg FWD 200000    128.66   P2p Edge
Fa2/0/11            Desg FWD 200000    128.67   P2p Edge
Fa2/0/12            Desg FWD 200000    128.68   P2p Edge
Fa2/0/13            Desg FWD 200000    128.69   P2p Edge
Fa2/0/18            Desg FWD 200000    128.74   P2p Edge
Fa2/0/20            Desg FWD 200000    128.76   P2p Edge
Fa2/0/22            Desg FWD 200000    128.78   P2p Edge
Fa2/0/25            Desg FWD 200000    128.83   P2p Edge
Fa2/0/27            Desg FWD 200000    128.85   P2p Edge
Fa2/0/30            Desg FWD 200000    128.88   P2p Edge
Fa2/0/31            Desg FWD 200000    128.89   P2p Edge
Fa2/0/35            Desg FWD 200000    128.93   P2p Edge
Fa2/0/36            Desg FWD 200000    128.94   P2p Edge
Fa2/0/38            Desg FWD 200000    128.96   P2p Edge
Fa2/0/40            Desg FWD 200000    128.98   P2p Edge
Fa2/0/41            Desg FWD 200000    128.99   P2p Edge
Fa2/0/42            Desg FWD 200000    128.100  P2p Edge
Gi1/0/1             Desg FWD 20000     128.1    P2p Edge
Fa1/0/2             Desg FWD 200000    128.4    P2p Bound(STP)
Fa1/0/8             Desg FWD 200000    128.10   P2p Edge
Fa1/0/9             Desg FWD 200000    128.11   P2p Edge
Fa1/0/11            Desg FWD 200000    128.13   P2p Edge
Fa1/0/12            Desg FWD 200000    128.14   P2p Edge
Fa1/0/13            Desg FWD 200000    128.15   P2p Edge
Fa1/0/16            Desg FWD 200000    128.18   P2p Edge
Fa1/0/18            Desg FWD 200000    128.20   P2p Edge
Fa1/0/19            Desg FWD 200000    128.21   P2p Edge
Fa1/0/20            Desg FWD 200000    128.22   P2p Edge
Gi1/0/3             Desg FWD 20000     128.27   P2p Edge
Gi1/0/4             Desg FWD 20000     128.28   P2p Edge
Fa1/0/26            Desg FWD 200000    128.30   P2p Edge
Fa1/0/27            Desg FWD 200000    128.31   P2p Edge
Fa1/0/31            Desg FWD 200000    128.35   P2p Edge
Fa1/0/38            Desg FWD 200000    128.42   P2p Edge
Fa1/0/39            Desg FWD 200000    128.43   P2p Edge
Fa1/0/42            Desg FWD 200000    128.46   P2p Edge
Fa1/0/43            Desg FWD 200000    128.47   P2p Edge
Fa1/0/46            Desg FWD 200000    128.50   P2p Edge
Gi3/0/1             Desg FWD 20000     128.109  P2p
Gi3/0/2             Desg FWD 20000     128.110  P2p Edge
Gi3/0/5             Desg FWD 20000     128.113  P2p Edge
Gi3/0/6             Desg FWD 200000    128.114  P2p Edge
Gi3/0/7             Desg FWD 20000     128.115  P2p Edge
Gi3/0/8             Desg FWD 200000    128.116  P2p Edge
Gi3/0/9             Desg FWD 20000     128.117  P2p Edge
Gi3/0/11            Desg FWD 20000     128.119  P2p Edge
Gi3/0/12            Desg FWD 20000     128.120  P2p Edge
Gi3/0/13            Desg FWD 20000     128.121  P2p Edge
Gi3/0/14            Desg FWD 20000     128.122  P2p Edge
Gi3/0/15            Desg FWD 20000     128.123  P2p Edge
Gi3/0/16            Desg FWD 20000     128.124  P2p Edge
Gi3/0/17            Desg FWD 20000     128.125  P2p
Gi3/0/18            Desg FWD 20000     128.126  P2p
Gi3/0/19            Desg FWD 20000     128.127  P2p Edge
Gi3/0/20            Desg FWD 200000    128.128  P2p Edge
Gi3/0/21            Desg FWD 20000     128.129  P2p
Gi3/0/22            Desg FWD 20000     128.130  P2p
Gi3/0/23            Desg FWD 20000     128.131  P2p
Gi3/0/24            Desg FWD 20000     128.132  P2p
Gi3/1/1             Desg FWD 20000     128.133  P2p
Gi3/1/3             Root FWD 20000     128.135  P2p
Gi3/1/4             Desg FWD 20000     128.136  P2p
MST1
  Root ID    Priority    24577
             This bridge is the root
  Bridge ID  Priority    24577  (priority 24576 sys-id-ext 1)
Gi3/1/3             Desg FWD 20000     128.135  P2p
I typed in
no spanning-tree portfast
that made the problem go away.  I am not sure that is the best solution though.
If you typed that in on just the port connecting to the switch stack then that is the correct thing to do.
You should not have portfast enabled on any ports that interconnect switches.
Jon
Thanks for the outputs. They do confirm that I was on the right track and that bpduguard is enabled.
I agree with Jon that disabling it on that particular interface is the correct solution.
Rick
Rick
