port-security on ISR 1111
Mario Erceg
Dear,
I have Cisco ISR 1111 router with 8 switch ports. I wanted to configure "switchport port-security" but I have no command. I use Fuji IOS XE 16.7. Is there any other similar command?
r.heitmann
since i've been looking right now for an very-small MPLS-capable-router, which the ISR1111 might be...
asking about port-security
* no hint to this feature in the IOS-XE-Configuration-Guides
* the Feature-Navigator (www.cisco.com/go/fn) => search by feature
...this tool is very often useful but sometimes it's database is not complete
=> shows no ISR-Router with "port-security" enabled (screenshot attached).
Zone-Based-Firewall might be an (maybe overengineered) solution!?
r.heitmann
It is strange because it has dot1x. Can I use mac access-list on switch port and control L2 access?
