Unknown protocol Drops on 3900 router
SACHIN SHARMA
can someone explain why i am seeing unknown protocol drops on the interface and also unknown media type detected and this is a MPLS WAN interface.
GigabitEthernet0/0 is up, line protocol is up
Hardware is PQ3_TSEC
  MTU 1500 bytes, BW 20000 Kbit/sec, DLY 100 usec,
  reliability 255/255, txload 25/255, rxload 49/255
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is unknown media type
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 01:15:00
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 38
  Queueing strategy: Class-based queueing
  Output queue: 0/1000/0 (size/max total/drops)
  5 minute input rate 3910000 bits/sec, 579 packets/sec
  5 minute output rate 1976000 bits/sec, 475 packets/sec
     2045331 packets input, 1515620832 bytes, 0 no buffer
     Received 154 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog, 151 multicast, 0 pause input
     1783756 packets output, 1109751258 bytes, 0 underruns
     151 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.0(1)M1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
sh run int gig0/0
Building configuration...
Current configuration : 208 bytes
interface GigabitEthernet0/0
description ATT MPLS Circuit ID: xxxxxxxxxxxxxxx
bandwidth 20000
no ip address
ip nbar protocol-discovery
duplex full
speed 100
max-reserved-bandwidth 100
end
John Blakley
Unknown protocol drops are anything that the router doesn't understand. The most common cause is DTP frames from the switchport. If you turn negotiation off and clear counters, you may see that they're not incrementing any longer.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
John ,
this interface is a uplink to service provider WAN router, we dont know what is the device connected on their side?
Chakravarthy.
Not sure. Is this an ethernet handoff to an ATT switch? If so, you may have to contact them to see if they can turn negotiation off.
HTH,
John
From the fact that there is no IP address configured on the physical interface and from this line in the output of show interface
I believe that we can be quite confident that the router is connected to some type of Ethernet switch. Therefore it is somewhat likely that the unknown frames are DTP.
Rick
Rick
