unnable to get DHCP ip adress
nicanor00
I have catalyst 2960 and router 1841 with Vlan configured
Router is DHCP server for eache VLAN
I also have ISE(192.168.101.60)
on central site
But user cannot get IP address
When I connecte on switch port interface GigabitEthernet0/1, I get an IP address
But when I connecte on switch port interface GigabitEthernet0/11, I cannot get an IP address from DHCP
Normaly all interface should have the same configuration as interface GigabitEthernet0/11
Please have a look on my configuration attached and help me to resolv my problem
cadet alain
You are doing 802.1x authentication with MAB on g0/11 and not on g0/1 so the problem comes from the authentication.
Why aren't you doing 802.1x on the other ports but only on this one ?
If you still want to use dot1x on this port you'll have to debug on the switch and  see the logs on the ISE to see why it is not working.
Alain
Yes the goal is to have authentication on all port
Normaly I should get IP address befor get authenticate
But I cannot get IP addresse
My issue is why I cannot get IP address
Thanks in advance for help
I have seen a fewer issues.
1) Shouldn't use "ip helper" because the default-netwark is in your subnet. ip helper only when have a DHCP server remote.
2) I recommend that the number of dot1 that is the same of number of vlan.
VLAN 2    interface fa0/1.2
               encapsulation dot1q 2
3)Dind't use the "ip dhcp excluded-address " to avoid binding conflicts.
Attache the tpology on Packet Tracert.DHCP_Laptop.jpghttps://dl.dropboxusercontent.com/u/94966688/DHCP_Issue.pkz
Best regards,
http://networkingcontrol.wordpress.com/
#CCNP CSCO11962956
http://networkingcontrol.wordpress.com/ #CCNP CSCO11962956
