Unsuppress Map
ajkelsey78
I have two routers, R6 and R7. I aggregated routes to R6 and used a suppress map to stop 172.20.1.0 and 172.20.4.0 from being advertised. It worked. I then configured an unsuppress map to advertise those two routes to R6. However, it has been unsuccessful. (this is a learning exercise)
16 Replies 16
MHM
Summary-only did not solve the issue. The unsurpress map still isn't passing the routes to R6.
did you clear ip  bgp ?
you need to clear ip bgp to make config take effect
then check in R6 172.20.1.0 and 172.20.4.0
MHM
I did. Also, the routes being advertised to change.
Before:
After:
I run lab and it work perfect
can I see last code you use
Try my config files.
What last code you use' share it here
The config in your original post dont include summary only and I done sure what else change.
MHM
Hello @ajkelsey78
Try stating a prefix specific of the the summary and not a default route to unsuppress
Kind Regards
Paul
I tried using 172.20.0.0/21 with no luck.
Hello
If you wish to initially suppress/unsuppress certain routes to ALL peers at the same time then you use the suppress-map
Example1:
route-map Suppress-Map deny 10  <--- all routes specified in the deny RM WILL NOT be suppressed
match ip address Suppress-1-4
route-map Suppress-Map permit 100
or
route-map Suppress-Map permit 10  <--- all routes specified in the permit RM WILL be suppressed
aggregate-address 172.20.0.0 255.255.248.0 suppress-map Suppress-Map
Example2:
If you wish to initially suppress certain routes to ALL peers at the same time and then unsuppress to a particular peer then you use a unsuppress map
ip access-list standard ALLOW-ALL-TO-R6
permit 172.20.1.0 0.0.0.255
route-map Unsuppress-Map
match ip address ALLOW-ALL-TO-R6
neighbor <r6> unsuppress-map Unsuppress-Map
Example3:
If you wish to initially suppress ALL routes to ALL peers at the same time and then unsuppress to a particular peer then you can use the summary only command without any suppress-map then utilise an unsuppress-map for particular peers to advertise specific routes along with the summary route
aggregate-address 172.20.0.0 255.255.248.0 summary-only
Kind Regards
Paul
apologize but Ex2 is same as Ex3
you use aggregate with suppress ALL which is same as aggregate with summary-only
MHM
Hello @MHM Cisco World
not so sure I understand..
Example2 =  certain specfic routes not ALL specific routes are being suppressed based on the OPs already assigned route-map and acl
Example3 = ALL specific routes are being suppressed using the summary-only command and then a unsuppress map is used again based on the OP already assigned route-map and acl
Kind Regards
Paul
Suppress-1-4  <<- Maybe I get this wrong' I was think this include all prefix.
MHM
ip access-list standard Suppress-1-4
 permit 172.20.4.0 0.0.0.255
Kind Regards
Paul
