ISR4431 IPBase license question
billybong
Hi, i have a strange one here regarding the IPBaseK9 license indformation
from the show ver it show IPBaseK9 is current
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None None None
uck9 None None None
securityk9 None None None
ipbase ipbasek9 None ipbasek9
but
Router#sh lic
Index 1 Feature: appxk9
Period left: Life time
License Type: RightToUse
License State: Active, Not in Use, EULA accepted
License Count: Non-Counted
License Priority: Low
Index 2 Feature: uck9
Period left: Not Activated
Period Used: 0 minute 0 second
License Type: EvalRightToUse
License State: Active, Not in Use, EULA not accepted
License Priority: None
Index 3 Feature: securityk9
Index 4 Feature: ipbasek9
Index 5 Feature: FoundationSuiteK9
Router#sh lic feat
Feature name Enforcement Evaluation Subscription Enabled RightT
oUse
appxk9 yes yes no no yes
uck9 yes yes no no yes
securityk9 yes yes no no yes
ipbasek9 no no no no no
FoundationSuiteK9 yes yes no no yes
AdvUCSuiteK9 yes yes no no yes
cme-srst yes yes no no yes
hseck9 yes no no no no
throughput yes yes no no yes
internal_service yes no no no no
Router#
whats everyones opinion , is this router licensed for IPBaseK9
7 Replies 7
Hello @billybong
Yes, your ISR4431 has an IPBasek9 feature license set. IPbasek9 is the lowest level feature license for ISRs and comes as a default license. For any additional feature license, you need to purchase a license and install it on the ISR.
***Please mark all helpful posts***
Spooster IT Services Team
balaji.bandi
This what it is show
Router#sh lic
BB
Thanks guys i understand its the base feature but my customer is not happy, he thinks IPBaseK9 should be enabled like the picture
Can you post below outout
show version
dir
BB
Router#
Router#sh ve
Cisco IOS XE Software, Version 16.06.07
Cisco IOS Software [Everest], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Ve
rsion 16.6.7, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Mon 23-Sep-19 14:36 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2019 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
Router uptime is 4 hours, 24 minutes
Uptime for this control processor is 4 hours, 27 minutes
System returned to ROM by Reload Command
System image file is "bootflash:isr4400-universalk9.16.06.07.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
appxk9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
uck9 None None None
cisco ISR4431/K9 (1RU) processor with 1796035K/6147K bytes of memory.
Processor board ID FGL225230GL
4 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
6598655K bytes of flash memory at bootflash:.
0K bytes of WebUI ODM Files at webui:.
Router#dir
Directory of bootflash:/
11 -rw- 554053832 Mar 12 2021 10:39:35 +00:00 isr4400-universalk9.1
6.06.07.SPA.bin
712449 drwx 4096 Mar 12 2021 10:46:50 +00:00 .installer
161921 drwx 4096 Mar 12 2021 10:48:56 +00:00 core
80961 drwx 4096 Mar 12 2021 10:47:12 +00:00 .prst_sync
631489 drwx 4096 Mar 12 2021 10:26:51 +00:00 sysboot
275265 drwx 4096 Mar 12 2021 10:47:19 +00:00 .rollback_timer
12 -rw- 0 Mar 12 2021 10:47:30 +00:00 tracelogs.Lsu
129537 drwx 4096 Mar 12 2021 10:52:42 +00:00 tracelogs
728641 drwx 4096 Mar 12 2021 10:47:46 +00:00 virtual-instance
13 -rw- 30 Mar 12 2021 10:48:55 +00:00 throughput_monitor_pa
rams
6650826752 bytes total (5148135424 bytes free)
Router#
EPIT
Hi Billybong,
Was you issue resolved? I got the same case.
BeeM
Hi, I have got the same issue as well. Have you managed to resolve it?
appxk9 disable None disable
securityk9 securityk9 RightToUse securityk9
