Update BGP routing table after advertised new subnet?
tinhnho123
Level 2
Level 2
Hi Guys,
After I add a subnet 192.168.20.0/24 into BGP, should I use
clear ip bgp *
or
clear ip bgp * soft
to update the bgp route to the neighbors?
router bgp xxxx
  bgp log-neighbor-changes
  neighbor 10.0.0.1 remote-as 123
  neighbor 10.0.0.1 version 4
address-family ipv4
   network 192.168.20.0 mask 255.255.255.0
   network 172.16.0.0 mask 255.255.255.0
exit-address-family
Thanks.
2 Accepted Solutions
the bgp is slow so you need to force bgp to advertise the new network
do
clear ip bgp 123
and check the neighbor
I run small lab show you that how bgp is slow, I add network but still neighbor is not receive it
immeidate after clear the neighbor get the network.
@MHM Cisco World ,
It does not matter since the second route is a /16. What we want the original poster to investigate is why there is no 192.168.20.0/24 in the local RIB. Until that happens, the network statement is useless and the route will not be advertised to the peer in AS123 (10.0.0.1).
18 Replies 18
I use usually
clear ip bgp <123>  <<- I use 123 as your sharing config
this force bgp to re-establish and exchange the new BGP session and advertise new update.
Harold Ritter
Hi @tinhnho123 ,
You should not have to. Just make sure that the subnet 192.168.20.0/24 is present in the RIB. This is a requirement for BGP to originate the route when you configure a network statement.
Sorry for the newbie question; how do I ensure it is present in RIB?
Thanks.
Hi @tinhnho123 ,
show ip route 192.168.20.0
tinhnho123
Level 2
Level 2
I did a quick
show ip route
from the local router and it looks like the subnet 192.168.20.0/24 is advertised from my neighbor, i checked the neighbor's router, it doesn't advertise subnet 192.168.20.0/24.
R1#sh ip route 192.168.20.0/24
Routing entry for 192.168.20.0/24
Known via "bgp xxx", distance 20, metric 0
Tag 123, type external
Last update from 10.0.0.1 1w1d ago
Routing Descriptor Blocks:
* 10.0.0.1, from 10.0.0.1, 1w1d ago
opaque_ptr 0xxxxxxxxx
Route metric is 0, traffic share count is 1
AS Hops 1
Route tag 123
MPLS label: none
I want my local router to advertise this subnet 192.168.20.0/24, shall I run 'clear ip bgp 123' on my local router?
do
clear ip bgp 123
Thanks!
Hi @tinhnho123 ,
Looking at the
show ip route
its appears this route is being learnt from neighbor 10.0.0.1 (as123) already. So why would you want to advertise to that same neighbor?
I just checked, the neighbor doesn't advertise that subnet.  My coworker probably advertised the subnet 192.168.20.0/24 from the neighbor to my local router and then removed it from the neighbor's router.
I want to advertise this subnet 192.168.20.0/24 from my local router to the neighbor.
Can you post the
output again?
Routing entry for 192.168.0.0/16
opaque_ptr 0xxxxxxx
AS Hops 1
Route tag 123
MPLS label: none
R1#
Hi @tinhnho123 ,
192.168.20.0/24 is resolvable via 192.16.0.0. The reason you are not advertising the subnet 192.168.20.0/24 to the neighbor is that you do not have the /24 present in the local RIB. For the BGP network statement to work, you need a matching route in the RIB. Do you have that subnet defined locally? If not how are you supposed to forward traffic to that subnet?
@Harold Ritter @tinhnho123
why I see two route one with /24 and other with /16 are you using redistribute ?
Hi @MHM Cisco World ,
The /24 was seen when his colleague advertised from the peer. After his colleague removed it from the remote peer, they are left with the /16 in the local RIB. This is the reason his BGP network statement does not work.
