Upgrade IOS 8500L in install mode
marzi
Hi all
I should have to do a IOS upgrade on two new C8500L-8S4X just purchased.
The new release will be IOS Cupertino-17.9.3a.
I've read that I could do it using install mode method.
https://www.cisco.com/c/en/us/td/docs/routers/cloud_edge/c8500/software-configuration-guide/c8500-software-config-guide/Package_Management-1.html#con_1057846
Usually about the Cisco 9300 I used the following commands :
Switch#copy usbflash0:cat9k_iosxe.xxxxxxxx.bin flash:
Switch(config)#boot system flash:packages.conf
Switch(config)#no boot manual
Switch(config)#exit
Switch#install add file flash:cat9k_iosxe.xxxxxxxxxx.bin activate commit
instead, the cisco 8500L need the following sequence :
Switch#copy usbflash0:cat9k_iosxe.xxxxxxxx.bin bootflash:
Well, now I see some differences :
In the copy command, flash become bootflash
in the same time, there are no more :
So, only two line command are enough for upgrade 8500L ?
If anyone have done the upgrade yet
Whatever suggest is wellcome.
8 Replies 8
M02@rt37
Hello @marzi
The install mode process flow comprises three commands to perform installation and upgrade of software on platforms–install add install activate , and install commit .
Only one image can be installed in a device that's why you have "only" do that.
Best regards
Hi M02@rt37
Thanks for your reply,
If I have understood correctly, the command's sequence about three-steps is :
Device#copy usbflash0:c8000.xxxxxxxx.bin bootflash:
Device#install add file bootflash:c8000xxxxxxx.bin
Device# install activate (auto-abort-timer starts automatically)
Device#install commit
while the command's sequence about one-steps is :
Device#install add file bootflash:c8000xxxxxxx.bin activate commit
I've added the copy command just only for complete.
For me now is clear.
If you or anyone want add someting....
Have a nice day guys
So does this combo command take care of the ROMMON too?
Please refer the link below -- It is not long and has pictures (for easy reading).  It will answer the question about ROMMON.
Cisco ISR & ASR 1k Routers: IOS-XE/Firmware Upgrade (Install Mode)
Three commands is an old TAC recommendation.  I have been using the one-shot "install add file flash:cat9k_iosxe.xxxxxxxxxx.bin activate commit" as far back as 2016.  Newer firmware versions (GUI) now has the "one-shot" command as an option.
I formulated the one-hit-wonder (because I can stop the switch/router/WLC from rebooting).  This means I can reboot the router/switch/WLC at a time and date of my choosing without, of course, using any other tools (like DNAC).
Hello @Leo Laohoo,
Thanks for that clarification.
Best regards
Leo Laohoo
Hello
The following sequence would be applicable:
dir usb0:
copy usb0:xxxxxx.bin flash:
verify /md5 flash:xxxxxx.bin
conf t
boot-start-marker
no boot system bootflash:
boot system bootflash:packages.conf
boot-end-marker
exit
wr
install add file flash:xxxxxx.bin activate commit
Once the rtr has reloaded
install remove inactive  to remote unnecessary pkgs.
show install summary
Kind Regards
Paul
